head swaping - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-05-2009, 12:30 PM   #1 (permalink)
GreenFlames's Avatar
head swaping
Howdy,
I was wondering if it is possible to put a 20R head on a late 22R block? I have done some reading up on it but i couldnt quite figure it out, so i thought i would ask the experts.
__________________
Some people brag about how fast the truck is, some about how much mud and dirt, and others about how much it can pull. But me I dont brag, because well you see I have green flames running down both sides, what else is there to say, except......IT WAS BORN AWESOME!
GreenFlames is offline
Old 11-07-2009, 09:04 AM   #2 (permalink)
toyotabull's Avatar
IF you put a 20r head on a pre85 block it will work with the dome pistons. I just done this with flat top pistons in a pre 85 block and for some reason I am getting around 110 psi on the cylinders. Now the 85 and newer block is shorter than the pre 85 so run flattops, or make dang sure you have the clearance between valve and piston if you run a big cam or 22r valves in a 20r head. Ive been looking this up trying to figure out my compression for the last few days. The funny thing is that even with that low of comp on mine( i think the comp gauge might be bad and I wasnt there to do it) it runs like a bat out of hell with a 270 cam. Good luck and get with engnbldr to make sure you get the right parts. timing chain and cover for the right block. Good luck and let me know what happens
__________________
85 toyota rancho lift
33 in tires on 15X8 steel
270 lift cam and flat tops
Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again!
toyotabull is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
