Hard on for turbochargers? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-05-2007, 10:44 PM   #1 (permalink)
CoedNaked's Avatar
I'm curious if somene in here could tell me why everyone seems to have a big hard on for turbo chargers over superchargers? Yes I understand that turbochargers "apparently" tend to require less drain/pull from the engine to make their boost by using exhaust flow to turn the turbine. But the HP superhcargers use off the pulley to turn their impellers couldn't be *that* much more to offset the advantages that superchargers offer, namely no issues with turob lag, way less installation issues, much easier to install and uninstall, cleaner looking engine bays, etc. Is there something I am missing here?
__________________
1993 Xtra Cab Pickup | 4x4 | 3.0 - V6 | R150F | Silver-Grey | Amsoil 10w30 synthetic oil | Amsoil Synthetic Drivetrain fluids|
Borla Cat-back Exhaust | OME HD Leaf Springs | Bilstein HD Shocks | Downey Idler Arm Brace | Grey Husky Liners | SR5 Bucket Seat Swap | Color matched Canopy | Yakima racks | Line-X OTR | Michelin LTX A/T 31 x 10.5 x 15 | 323,600 KM's (202,250 miles) | Made in Japan - Vin starts with "J"| Fish on
CoedNaked is offline
Old 12-05-2007, 10:50 PM   #2 (permalink)
apalmer1's Avatar
Personaly from what ive seen on YT the oppinions are rather split. Turbo's offer less resistance and take less power, and can produce WAY more boost and hp then a SC can, though on the flipside SC's have power on demand and produce much more low end torque. As well SC's are far more durable offroad as long as you are sure to bring spair belts. Though people will argue either way on the durability.
Im sure youve opened up a can of worms with this thread as it will probably just start the whole argument over again...
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress.
85 pickup, 327sbc, truggy, in progress.
86 mazda b2000 street queen haha.
92 mazda B2600i 4x4 absolutely mobs.
81 ford bronco drinks gas
90 mazda mx-5 all original.
when in doubt, tach it out.
apalmer1 is offline
Old 12-05-2007, 11:04 PM   #3 (permalink)
CoedNaked's Avatar
Well I can see the can of worms coming around. But I'd be interested if this can is opened, if there are any other details or points that I may have missed that may help me understand the turbocharger crowd a bit better.
EDIT: Here's a question for you - why don't you ever hear of Supercharged Diesel engines? It appears as though all they ever come out with are Turbo Diesels - why no supercharged diesels?
__________________
Old 12-05-2007, 11:26 PM   #4 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Diesles have great low end power, top end is where they drop off, and thats where turbos work best. At least thats what I made of it...
supercharger wine > turbo blow off valve
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 246,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 12-06-2007, 12:01 AM   #5 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
Quote:
i have, they were made by Detroit Diesel, most popular models were the 8v-71 and 8v-92 and some other models i cant think of right now, they were 2-stroke diesels but even with the blower they were considered naturally aspirated, the blower was needed just to run, the later models had turbos and blowers but still were NA, at high RPM the turbo had a bypass port to bypass the blower to give the engine extra air
Quote:
At the top of the cylinder are typically two or four exhaust valves that all open at the same time. There is also the diesel fuel injector (shown above in yellow). The piston is elongated, as in a gasoline two-stroke engine, so that it can act as the intake valve. At the bottom of the piston's travel, the piston uncovers the ports for air intake. The intake air is pressurized by a turbocharger or a supercharger (light blue). The crankcase is sealed and contains oil as in a four-stroke engine.
The two-stroke diesel cycle goes like this:
When the piston is at the top of its travel, the cylinder contains a charge of highly compressed air. Diesel fuel is sprayed into the cylinder by the injector and immediately ignites because of the heat and pressure inside the cylinder. This is the same process described in How Diesel Engines Work.
The pressure created by the combustion of the fuel drives the piston downward. This is the power stroke.
As the piston nears the bottom of its stroke, all of the exhaust valves open. Exhaust gases rush out of the cylinder, relieving the pressure.
As the piston bottoms out, it uncovers the air intake ports. Pressurized air fills the cylinder, forcing out the remainder of the exhaust gases.
The exhaust valves close and the piston starts traveling back upward, re-covering the intake ports and compressing the fresh charge of air. This is the compression stroke.
As the piston nears the top of the cylinder, the cycle repeats with step 1.
From this description, you can see the big difference between a diesel two-stroke engine and a gasoline two-stroke engine: In the diesel version, only air fills the cylinder, rather than gas and air mixed together. This means that a diesel two-stroke engine suffers from none of the environmental problems that plague a gasoline two-stroke engine. On the other hand, a diesel two-stroke engine must have a turbocharger or a supercharger, and this means that you will never find a diesel two-stroke on a chain saw -- it would simply be too expensive.
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 12-06-2007, 12:06 AM   #6 (permalink)
mikes19984x4's Avatar
yeah superchargers are awesome with that classic blower "whine", but IMO, a turbo just can't be beat...i mean, it gives the engine more power from the engines exhaust (so it's not "using" any of the motor's power to make more power), it can be tweaked to make more boost, which = even more power, and i guess b/c i'm such a big diesel fan, the spool-up and blow-off valve sounds are cooler to me, but that's just IMO...
__________________
1998 4Runner SR5 4x4
3.4 w/5-speed & E-Locker
Deckplate & ISR mod w/K&N, 2.5-inch Exhaust w/40-Series Flowmaster
Centerforce Clutch
Bilstien Shocks, 265/75/16 Buckshot Mudders
Sylvania Silverstars, Hella 500s on front bumper (no longer), Orange Gauge Lights, JVC Arsenal Head Unit, Pioneer REV-Series Speakers
More mods to come...
mikes19984x4 is offline
Old 12-06-2007, 12:13 AM   #7 (permalink)
strykersd's Avatar
I prefer a turbo charger because it is power when you need it. Say it doesn't spool until 3500RPMs, until then it's like you have a normal naturally aspirated engine. Thus saving gas yet having the power when you need it.
__________________
Patrick
86 Toyota 4runner - Toy
97 Honda Civic - Daily Driver
89 Honda CRX SI - SOLD
97 Ford F-150 - Fixer-Upper
strykersd is offline
Old 12-06-2007, 12:56 AM   #8 (permalink)
notanymore's Avatar
i like superchargers over turbo because of having the power on hand, not having to step on the gas and wait for it
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust 120amp Mr. Alternator rear lockrite, optima yellow top
xrc8 winch & AOR bumper coming soon
my bikes: 1980 Honda CX500-1997 honda cbr F3
notanymore is offline
Old 12-06-2007, 12:57 AM   #9 (permalink)
thebusine$$'s Avatar
Just curious to know if there are any major manufacturers that make outstanding turbochargers for 3rd Gen. 4Runners?
thebusine$$ is offline
Old 12-06-2007, 01:13 AM   #10 (permalink)
fastkevman's Avatar
With newer turbo designs and proper tuning there is very little lag, you won't notice at all.
Original supercharger designs, "gmc" roots-style blowers used by early drag-racers are actually revamped industrial or diesel blowers.
Also, instant power from a supercharger is a myth as their rated psi is on the top end, therefore just like a turbo the faster it spins the more air it pushes.
You can put together a homemade cheap turbo set-up quite easily with a farm equipment turbo that would make tons of power for less than $1000, the cheapest supercharger, be it roots-style or centrifugal will cost $2500 or more.....ouch!
fastkevman is offline
Old 12-06-2007, 01:38 AM   #11 (permalink)
stormin94's Avatar
For me, It would really depend on what I was using my car for, and what kind of car it is. For example, I'd much rather have a supercharged SUV than a Turbo, esp for low speeds(and low RPM, too). I'd like to have a turbo on a diesel, or a BMW sports car. I'd want a supercharger on a muscle car, or on a large gasoline engine (IE, the 4.3 chevy, the 5.7 chevy, and pretty much anything over 350CI). On a Z06 Corvette, which is fast enough as it is, I'd like a Supercharger. I guess all in all, I like superchargers better. I'm not sure why, but I think the whole ricer scene kind of ruined turbos for me a little bit.
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 12-06-2007, 01:48 AM   #12 (permalink)
apalmer1's Avatar
Quote:
Its not all about power though, there is also durability and driveability to consider, as well as the most important one, offroadability Most turbochargers just cant live up to the simplistic, enclosed, bolt on design of an SC, as well as they are not positioned as high up on the block which makes them even more succeptible to water damage. Im not saying that there arent some incredibly durrable and efficient turbo's out there that can be used for offroad, but i am saying that for the price the general consumer is going to get better end results from a supercharger.
__________________
apalmer1 is offline
Old 12-06-2007, 02:05 AM   #13 (permalink)
Matt16's Avatar
The fuel economy turns me off superchargers. I'd like to put a bi-turbo setup in my 22RE. A little turbo to spool up fast for power on tap and the a bigger turbo for higher revs. In the perfect word, I'd just have a turbo diesel 4Runner.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 12-06-2007, 07:34 AM   #14 (permalink)
tc
tc's Avatar
First, let's have a little lesson.
A turbocharger IS a supercharger. A supercharger compresses the intake air to provide more oxygen so you can burn more fuel. As simple as that.
The difference in the two is the way the compressor is driven. A turbocharger is a special kind of supercharger that uses the exhaust gas to drive a radial turbine compressor.
What people are talking about above are their experiences in the execution of the idea. There are many poorly executed designs out there. You can make a supercharger that has the high end boost like a turbo and you can make a turbo with NO lag like a supercharger - and there are plenty of both out there.
Since a turbo is ALWAYS remote mounted, it is easier to intercool it to boost that oxygen density even further. As mentioned above, though, that comes at the expense of complex exhaust routing.
Typically, a supercharger is easier to install, but does have some parasitic drag and, for the intake mounted versions especially, they are harder to intercool.
Because of the high compression ratios diesel engines operate at, they have a lot of energy in their exhaust streams which are "ripe pickings" for a turbo. From a factory standpoint, turbos have the advantage of quieting the exhaust and reducing the exhaust temp which helps them meet EPA requirements.
http://auto.howstuffworks.com/supercharger.htm
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-06-2007, 10:27 AM   #15 (permalink)
Quote:
http://www.lingenfelter.com/Lingenfe...boCorvette.htm
i bet this kit for a Z06 would make you change your mind about a supercharger...and they even had a corvette for a car & driver test that was making more HP than this kit...1000+ HP!
__________________
Centerforce Clutch
Old 12-06-2007, 03:59 PM   #16 (permalink)
agusgus3's Avatar
Quote:
Of course it comes down to design of the system and what you want out it. Turbo systems designed correctly for your goals, are superior to SC, with the appropriate maintenance.
Again, begging the question i had earlier, T25-42AR turbine, 48AR compressor, 2.7L 3RZ; any takers on full boost before say 2k?
agusgus3 is offline
Old 12-06-2007, 04:21 PM   #17 (permalink)
xcmountain80's Avatar
Just dont get your hard on stuck in the turbo.
Aaron
xcmountain80 is offline
Old 12-06-2007, 04:55 PM   #18 (permalink)
foot0069's Avatar
Tc is on time. Take a look at a top fuel car sometime blowers rule no mater what drives em. They are all usually built to pull after they start to spool up some. Rock crawlers need the low end umph. Turbo's need a lot of engineering to get that. But check this out.
http://www.nelsonracingengines.com/video_drive.html
Ya gotta like that
Jim
foot0069 is offline
Old 12-06-2007, 11:22 PM   #19 (permalink)
stormin94's Avatar
I like the twin turbo escalade that they did with 800 horsepower!!!
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 12-07-2007, 04:42 PM   #20 (permalink)
KZN185W's Avatar
Quote:
A turbocharger IS a supercharger....
there are 2 types of forced induction systems: one type is the turbocharger (powered by engine exhaust) and the other is the supercharger (powered by the engine pulley).
although both have the same function (to increase engine performance), the two are still different and a turbocharger is not a supercharger.
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats
Drive Your Dreams
KZN185W is offline
Old 12-07-2007, 04:56 PM   #21 (permalink)
88Yota4runner's Avatar
Send a message via AIM to 88Yota4runner Send a message via MSN to 88Yota4runner Send a message via Yahoo to 88Yota4runner
lets all just get along and build a 4runner with a turbocharger AND supercharger nwgaaagaha *imhigh*
__________________
* 3 inch Body Lift *
* Homemade Snorkel *
* 34" 10.50 Super Swampers *
* FlowMaster Exhaust *
* 4 point harnesses *
88Yota4runner is offline
Old 12-07-2007, 05:28 PM   #22 (permalink)
b.miller123's Avatar
umm....................................
tc was right, and as much as I hate to start arguements, you are wrong, a "turbocharger" is just another version of a supercharger, that happens to be turned be a turbine that sits in the exhaust system, instead of a belt
The closest design of a supercharger that is widely known is the centrifugal superchargers that vortec is making, basically it is the "back-half" (or intake-half) of a "turbocharger" and instead of being driven by exhaust, it's driven by a belt
and as much as I hate to quote wikipedia:
http://en.wikipedia.org/wiki/Supercharger
it's in the very first paragraph
or,
http://en.wikipedia.org/wiki/Turbocharger
it's in the very first sentence
__________________
As well as fear, Chuck Norris can also detect hope.
For example: "I hope I don't get a roundhouse kick to the face from Chuck Norris."
1993 Ex-cab 4x4 3.0 5spd,
155xxx mi. and counting,
AND YES, IT DOES HAVE A TAPE PLAYER
b.miller123 is offline
Old 12-07-2007, 06:29 PM   #23 (permalink)
tc
tc's Avatar
It's also in the howstuffworks link I posted...
__________________
tc is offline
Old 12-07-2007, 09:00 PM   #24 (permalink)
yeah, i didn't see that part, I guess that he didn't either
__________________
Old 12-08-2007, 02:21 AM   #25 (permalink)
KZN185W's Avatar
http://auto.howstuffworks.com/turbo.htm
this one was made by a different author...i guess they also have differing opinions like we do here...
__________________
Drive Your Dreams
KZN185W is offline
Tags
22r, 8v71, comparison, detroit, injector, jdm, mods, performance, pulling, radiator, rousch, supercharger, te37x, turbocharger, upgrade, volk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How hard would it be to... Island_Yota Pre 84 Trucks 9 09-03-2007 04:53 PM
This shouldn't be so hard!!! old4runner 86-95 Trucks & 4Runners 13 03-20-2007 11:05 AM
Is it really this hard? oly884 Off Topic Talk 21 01-30-2007 11:26 PM
How hard..... 93toyotasr5 95.5-2004 Tacomas & 96-2002 4Runners 8 02-23-2005 05:05 PM
How hard??? Stump1883 Offroad Tech 6 02-14-2004 09:39 AM
2009 InternetBrands, Inc.
