Disc Brake Job Gone Bad Grinding- Help please - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-24-2009, 08:54 AM   #1 (permalink)
SWPERIC's Avatar
Send a message via AIM to SWPERIC
i put new front pads and rotors on my fathers FJ. He got EBC green stuff 7000 series pads.
the front has been making a grinding noise and when i inspected the rotor, at least the outside passenger side is getting majority etched and destroyed. there is a build up of material on where the pad meets the rotor as well. the other side is fine on the outside and i could not inspect the insides due to the dust shields.
do these pads need to go on in a certain position? even tho i found no documentation saying so? its the only reason i can conclude. im going to pick it up from him while he is a work on monday and get it to my garage to inspect it further, switch around pad order and see if i cant get the grinding to stop before I put on new parts.
any help would be greatly appreciated. Thank you YT.
__________________
My Build Thread
for sale. very cheap, almost free.
2002 4runner limited running boards (golden pearl) free to a good home. or any home at that
2002 runner stereo with 6 cd changer and external amp.
SWPERIC is offline
Old 10-24-2009, 09:30 AM   #2 (permalink)
pwd
pwd's Avatar
I'm definitely no expert, but on my '92 the pads wouldn't fit in the caliper correct. I then realized that there was a difference between the inside and outside pad. The difference was the pad wear indicators I think, they looked like small clips. Maybe just check and see. Although they were the same thickness so it shouldn't cause grinding.
__________________
1995 4x4 ext. cab Truck 3.0L 5-speed
Bone stock, with Wab-Fab Shackles Rear Wide 6" $100
Acquired in May 07 , spent ~ $4400 on repairs so far:
Paint job, parking brake cable, rad re-core, new tire winch, brake lines, fuel line, Bremo rotors, Toyota pads, new calipers (in this order), all new exhaust excluding headers
1992 4Runner 4x4 3.0L Auto
Project Truck... the deeper money pit.
Update Nov. 19: Fully road worthy. New Tires Coming Soon.
pwd is offline
Old 10-24-2009, 10:02 AM   #3 (permalink)
tc
tc's Avatar
Which brake system does it have?
The new system (4 port, digital master cylinder) is NOT shadetree-mechanic friendly.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 10-25-2009, 11:10 PM   #4 (permalink)
SWPERIC's Avatar
wow. i installed a pad backwards... i feel like an idiot. mods, please delete this thread because its useless
__________________
My Build Thread
SWPERIC is offline
Tags
4runner, bad, brake, brakes, cost, disc, front, grind, grinding, grinds, job, noises, pads, rotors, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
