CatClamp - Initial Impression
Just installed the basic CatClamp model today on my 99 4Runner and while it is aesthetically intimidating, it doesn't seem too functional. I had a mechanic install it while putting on my new muffler and he brought up some very interesting points.
For those who aren't familiar with it, the CatClamp is a catalytic converter theft deterrent system. There are two collars and 4 aircraft quality cables include, in which you'd clamp one collar on each side of the piping extruding from the cat and then feed the wire through each collar with the holes provided.
PROS
-It looks like hell so if a thief snuck under your car, he would most likely crawl back out because it looks impossible to work on.
-No welding required, however a carlift would be advisable to install
CONS
EDIT: Well I did list them, but thanks to the community for thinking one step ahead, I've removed them because I basically listed how they could steal one.
I'm going back down to LA in a month, so I'll see what happens while I'm down there.
PROS
CONS
Cable is hard to cut with a sawzall.
Like most theft deterrent systems, if someone wants through it, they'll get through it, however the idea that "this will take too long, I'll hit that one over there" is pretty effective.
i hope a thief isn't reading this because he pretty much told how to steal a cat with this device on it
I do realize that I might have told tweakers how to steal a cat, but let's hope they don't run across this one page on the trillions of other webpages on the Internet.
That's what I thought too, but my mechanic sawed off about a foot off extra cable using a battery powered Sawzall with a $1 blade.
but i did google "how to steal catalytic converter with a catclamp installed" and this topic was the 3rd one listed but i agree with what you said..a worthless thief would look at that and go to the next car. Budbuilt said he was developing a type of skid plate to cover just the cat that would make it impossible to get too.lets hope these devices work..
Apparently my mechanic said only OEM cats are the ones thieves take because there's a lot more platinum and what not in them. Aftermarket ones aren't worth as much and thieves don't steal it... however I read that those who do steal cats are druggies anyways and they probably wouldn't know the difference between OEM and aftermarket?
Dude those druggies do know which cats to steal they only take the oem ones not the aftermarket ones , they want money ,they know what will get them that.
I'm hoping other ideas/alternatives than the cat-clamp are devised. There's definately a market for them since converter theft isn't going away anytime soon.
So just thought I'd point this out... using stock piping, the Cat Clamp will not fit properly. Also, be sure to have on hand plenty of zip ties because if you don't, you'll be hearing the vibration of the cables against the heat shield, which can be heard in the cabin. I had a mechanic install mine and he followed the instructions that came with the product word for word (sort of). I'll post some pictures later of what it looks like... it looks like hell.
foampile
12-18-2022 01:29 PM
