View Poll Results: what Air filter are you using?
Amsoil
131
25.14%
K&N
179
34.36%
TRD
26
4.99%
Stock Paper
158
30.33%
other
27
5.18%
Voters: 521. You may not vote on this poll
Which air filter?
#68
Bought TRD for my v6prerunner. Figure, its from toyota so it should be good. It says it filters better than stock. But common sense tells you that more air flow means more STUFF gets through. Oh well, still happy with it. Runs smother, shifts smother and seems to spool up faster. Can hear it sucking air from cold start if i'm in the passanger seat with the door open.
Who really makes these filters for TRD?
#72
Originally Posted by Gadget
It seems that when AMSOIL redigned their filter line they took a great filter for the Toyota trucks and turned it into less then great. WHY???
I have seen one of those UNI filters. Very interesting design indeed.
Gadget
Gadget
Mick
#74
I sell a Battez air filter for 2nd gens and 3rd gens, 3rd gen pictured below. It's washable and never needs oil. It's imported from Japan and runs around $120 at the discount price. I haven't seen any testing on it, but it's not cheap, that's for sure.
Here's the description I have:
High flow design, reusable Piper Cross Foam filters that out-perform OE and aftermarket foam filters, yet provide superior filtration qualities for maximum protection from dirt, dust, oil, mud and other harmful elements. Rinse clean using water for easy maintainance with no special oils or treatments required.
Might as well throw this into the mix and cause more confusion.
#75
I use the paper filter and pop off the airbox door. I use a 1 inch c-clamp to hold the filter tight against the airbox. I'm too lazy to do the deckplate mod and I realy don't want to chop my airbox. The only downfall is it makes the intake very loud, as does the deckplate I would imagine.
#76
Originally Posted by bike4miles
I had the K&N Drop in but just replaced it with the TRD cone filter which was a huge improvement. Had to custom make a brackett for it though.
Where did you get the TRD cone and how much was it? I've been looking for one for a '95 4runner. I don't trust the no-name things that can be found on ebay that are a cone style filter and a mass-air-flow connector.
#78
I have K&N plus deck lid mod did it all at once and availabilty was on K&N's side ....I have only had good results better horsepower with major gas milage bump(when not goofing off)
