5 speed fluid....?
Originally Posted by AH64ID
When you drain be sure to take the fill plug out first, otherwise when you pull the drain plug it will spash everywhere when it sucks air back in...
Originally Posted by gregbreakseverything
so you need a big hose to fill it? How much fluid do i need?
Look Here and get one of their pumps to do it...
Originally Posted by Glenn
Good idea... The main reason I always remove the fill plug first is that if it's stuck, I want to know about that before I need to add oil.
YEAH, I know that one.... good thing I removed it first....I had to wait until the tranny was out for a clutch to get enough torque on the plug to get it off...
#25
Originally Posted by spaugh
is it necessary to flush when going to synthetics? Or can I just drain and refill? I don't know what kind of oil in my transmission now, but I would like to change it since the car is used and I doubt the previous owner had it done.
David
#26
Changing the oil is rediculously easy. I put Valvoline in mine, haven't had any problems. Changed both the transfer case and the manual transmission at the same time. Took me about ~40 min start to finish.
If I had it to do over again, I would use a HAND PUMP to put the oil in instead of the syringe contraption I currently have.
Oh, and be waiting on that oil. Bob has a great writeup on it. And he ain't kiddin about saying it comes shooting out like a missile either!
I used THIS guide.
I used THIS guide.
#27
129Creepin
08-05-2015 10:12 PM
