will these rims fit a 97 4runner?
Old 12-17-2009, 09:58 AM
logsurfer's Avatar
these are the stock rims of an 87 4runner. i found them on cl for $90, went to myboltpattern.com to check, looked good but i want to know from those with first-hand experience.
Old 12-17-2009, 10:09 AM
HazMat's Avatar
bolt pattern is definatley the same. The only thing to worry about is the backspacing on these. If there is more backspacing on these rims than your stock ones you could run into problems especially if you are running a wider tire.
Old 12-17-2009, 10:14 AM
logsurfer's Avatar
wow that was quick! btw, im running P225/75R15 tires. wonder if these rims are lighter...
Old 12-17-2009, 10:15 AM
Dan.3's Avatar
Nope will not work unless you plan on down grading your brakes
Old 12-17-2009, 10:21 AM
logsurfer's Avatar
i like these rims!
06-01-2021 01:51 PM
crashburnoveride
07-10-2015 06:39 AM
icentropy
07-09-2015 02:12 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: will these rims fit a 97 4runner?
