why is gas pouring out muffler
i just bought a 1990 4runner the guy who owned it prev cracked the thermostat housing so i fixed that and got a new radiator hose and new spark plugs when i went to go turn it on it turns over but doesn't catch then fuel pours out the muffler and the engine was filled with gas
its a 3.0l v6 with 260k on it
yes last nite i checked the spark and it was yellow and very weak but it was sparking and i also did a compression check and it was good
Well sounds like its flooding something fierce. I would figure out why you have weak spark. Considering the age of the vehicle and being new to you, I would start by replacing the plugs wires cap and rotor.
Did the vehicle run when you first got it?
Next thing I would do is check it for codes and report back here!
That happened to me about a year ago. Filled my entire manifold up with fuel. Did it to me twice and then never again. I hate intermetant problems. Not quite sure why Toyota added a seperate injector for cold start when making the other ones richer till warm would work.
09-04-2015 09:27 AM
AppalachianOffRoader
08-12-2015 12:55 PM
