Whats the best way to upgdrade my DD to make it more offroad capable
^^^ that's a viable option. A should net you close to 4" if not you can always add a longer shackle to the mix. But you have to find someone to weld and relocate your front spring hanger. And either double shackle the rear or relocate the rear hanger as well.
This thread get a ton of views but no one post all members feel free to post im always looking to improve my truck
this is a link for what i was talking about for the rear.
http://www.pirate4x4.com/forum/showthread.php?t=20665
hope this helps!
hope this helps!
In the write up (if i understand it right) he says you dont have to lift the front IFS... but the swap is suppose to give you ~4" of lift. Isnt that contradictory or am i just reading it wrong??
To the original poster... I'm a novice as well and Ive got a 2" 4crawler IFS Susp lift and 2" 4Crawler body lift and its PLENTY of lift for 33's. Borderline too much but i like the look. If that 63 spring swap improves the ride as stated, Im in.
#25
#26
Ball Joint spacer, 33's, 4.56's (4.88's if it's an auto trans), maybe a locker, a selectable would probably be a must in snow conditions on a DD.
And lots of underbody armor. And sliders with a rear kickout if you really wanna wheel the thing. As they tend to save body panels.
No bracket lift or blocks. Nothing more than a 1" body lift IMO.
This is the correct answer. You want to keep your COG low. You will be miserable with a bracket lift and blocks with 35's for a daily driver, AND... it really won't really make it any more capable off road. The auto locker will, but that will make daily driving suck too.
#28
i have 1.5" bj spacers, 6 or 6.5" shackles, a welded rear and an open front diff and 31" cooper stt's..... i go plenty far, farther than my friends with the big lifted chevys who only lifted them to look cool and a few jeeps who have done the same. they want to exterior cool but dont have the interior needs(gears lockers etc). im content with my setup for now and am ordering sliders soon. after the sliders im saving for the solid axle and 35s with a front locker dual t-case and the others once i get the money to do it right.
You dont need a big lift to go far. ifs in the early years up until '95 works better stock with no mods.
Also, i have had my truck for over 3 years now and havent done alot majorly to it becasue i want something that i will always feel good about and want whats best for the trails around me and my likes. i had to hold back alot from getting a body lift for the cool look and really decided it wont do anything for me on the trail to get me farther. Whatever you do though, good luck and have fun doing it
#29
#30
Blocks are terrible. remove and discard. just get a locker. that is all. I was riding around on 32s and stock springs and running gear for almost 2 years, just recently went with a small lift. but my previous set up took me everywhere I wanted to go. use the "search" feature for info about this, there are a TON of threads that cover it.
#31
06-01-2021 01:51 PM
thzpcs
10-03-2015 07:39 AM
09-04-2015 09:27 AM
shadowbirdie
07-21-2015 10:38 PM
