What will these repairs cost?
Old 07-30-2010, 06:34 PM
JDS1992's Avatar
I was jus wondering if someone could give me an estimate on a few things that I need done to my 92 4Runner
1. A/C recharge/covert to R134a
2. BFG All Terrains, stock no lift.
3. Serpentine Belts
4. Timing Belt/ Water Pump replacement
-Thanks
Old 07-30-2010, 07:18 PM
Tubbyfatty's Avatar
Belts you can do yourself, search on here, same with the timing belt and water pump if you have some knowlege.
Tires are gonna be like $150-$200 a piece so there ya go.
AC recharge could be around 100 or so, not really sure.
Old 07-30-2010, 08:58 PM
BigSwole's Avatar
a recharge aint much you can do that yourself...converting it over is where the moneys going to be at...
check craigslist for tires...
Old 07-30-2010, 09:04 PM
MaK92-4RnR's Avatar
are you doing this yourself or having a mechanic do it?
1) not sure on the recharge mechanic wise but you can easily do that yourself, converting it will be what costs.
2) my 33x10.50 km2s were 806.50 with a 100 dollar rebate... i believe BFG had a $60 rebate going on right now. so... go get some quotes.
3) driving belts are pretty straight forward and simple, but if you're gonna have a mechanic do your timing belt, might as well add the driving belts into it
4) mechanic - 5-700 dollars for a 3vz.
Old 07-31-2010, 02:17 AM
JDS1992's Avatar
I was going to have a mechanic to do most of it..I can replace the serpentine belts myself but your right when im going to replace the timing belt, i might as well get the drive belts out of the way..
-Thanks for the feedback.
Old 07-31-2010, 06:50 PM
JDS1992's Avatar
im thinking about getting a 2" lift just so there is a noticable difference what should I do, 1" body 1" suspension lift, 2" body lift or 2" suspension lift? any ideas on what would look cool?
-Thanks
Old 07-31-2010, 07:01 PM
Fossilized
Staff
dropzone's Avatar
Lift options: search for the ifs lift sticky either at the top of this folder or the 86-95 folder
justdifferentials
Just Differentials
06-13-2022 07:40 PM
primordialbeast117
12-19-2015 12:23 PM
puddlepirate
09-29-2015 08:02 PM
Project90
09-24-2015 11:40 PM
Quick Reply: What will these repairs cost?
