Weird wheel noise at highway speeds
Old 05-31-2010, 02:50 PM
gdutch's Avatar
Hey guys,
Just got back from a 300 mile road trip this weekend and I noticed a strange noise coming from what sounded like my front driver side wheel. It wasn't the first time I noticed it, but it seems to have gotten worse. Here are the symptoms:
Between 60-75 miles per hour, when I let off the accelerator it makes a low-pitched hum, kind of mild grinding sound. Above 80 miles per hour, it does it constantly. When the noise happens, I can feel a mild vibration on the floor under the pedals. My truck does not pull to one side or the other that I can notice, it just makes the noise. The tires up front are still fairly new, only about 10k on them. I know I am in need of a brake job, and my alignment has been off for a while. I think that my brakes may be binding a little which is what causes it, but I'm not sure. Any thoughts? Keep in mind, this is a two wheel drive vehicle, so anything 4wd related will not come into play here.
Old 06-01-2010, 05:08 AM
kball's Avatar
The only thing that comes to mind for me would be a wheel bearing. Does the noise happen/change when you turn? Lift it and wiggle the tire side to side and up and down and see if there's play.
Old 06-01-2010, 12:07 PM
gdutch's Avatar
I don't notice anything when I turn. Like I said, it only happens at 60+ mph, and I'm not taking many turns at that speed :-p
Old 01-22-2011, 05:01 AM
Dok464's Avatar
Did you ever figure this out? I am having the same thing.
Thanks
MTLroadierunner
07-15-2015 12:58 PM
razorman8669
07-12-2015 12:13 PM
mlavery85
07-12-2015 10:33 AM
cars-guy
07-11-2015 07:51 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Weird wheel noise at highway speeds
