| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Water in drivers side floorboard
#2 (permalink) |
do you have a sunroof? I think there is a fron sunroof drain that runs through that a pillar.
__________________
-Chris Tread Lightly! 04 Double Cab PreRunner. 3.4 - Auto 84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50 Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris Great Toyota Tech |
#3 (permalink) |
Check your heater lines and see if the windshield is leaking anywhere
__________________
82 Shortbed with 22r, weber 32/36, civic seats, bedlined interior, 31” LTB’s |
#4 (permalink) |
There is a rubber grommet on the firewall near the brake booster under the hood where the wires come through. Have you made more holes in the grommet to pass extra wires through or anything? Check to see if it's installed properly. Take a garden hose and spray the grommet from the engine compartment side, and check to see if water is coming into the cab.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#5 (permalink) |
the above mentioned items are all possibilities. I would also check your door seal, sometimes they get compressed to the point it won't work. fix it so you don't end up with this on my driver's side:
![]() found this after fixing a leaky windshield and pulling up my carpet. Good luck..and welcome to Yotatech!
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#6 (permalink) | |
Quote:
CT Last edited by CanadianToy; 02-27-2008 at 04:54 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 93 4x4 pickup w/ slight clunk under drivers side floorboard | b1gmoose | Newbie Tech Section | 8 | 02-04-2008 10:46 AM |
| Strange sound near passenger side floorboard | 4runnin2 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-12-2007 05:55 PM |
| Drivers side mirror | adn3000 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-07-2007 08:28 PM |
| 99 3.4 weird grinding noise and water on drivers side? | justin1889 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-22-2006 05:29 AM |
| Anyone Know How to Replace Drivers Side Mirror | RandyM | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 10-21-2004 09:20 AM |
