upper and lower control arm bushings
Old 12-22-2010, 10:53 AM
muskie11's Avatar
I am new so please bear with me. I have a new set of bushings to put in a bare set of control arms. The bolts look to be quite a bit smaller than the i.d. of the bushings. Is there a inner sleeve that goes between the bolt and the bushing? I am starting with a bare frame so I don't have a set to go off of. Truck is a 93 ext cab 4x4. Thanks
Old 12-23-2010, 10:02 AM
MudHippy's Avatar
Yes, the upper and lower bushings have inner and outer sleaves. The lowers also have washers/ferrules at each end.
Lower bushing.
Upper bushings.
Old 12-23-2010, 11:51 AM
muskie11's Avatar
Thank you so much. I came upon a 93 totally ripped down to the frame, so I just don't have the tear down experience to tell me some of the things. So far it has been quite fun trying to figure out where everything goes. Fsm is great for parts, but its the bolt search that can get you scratching your head! I am sure I will be asking many more questions!
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
KyleT
07-21-2015 07:54 PM
ksmudrunner99
07-21-2015 05:33 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: upper and lower control arm bushings
