TPS issue on 22RE
Old 02-12-2011, 04:59 PM
dieseleater101's Avatar
TPS issue on 22RE
I have a 89 yota 4x4 with a 22RE from a 4runner(I was told) I got this truck on a trade a few days ago, and the guy said he runs it with the TPS unhooked. Went to start it in the morning and didnt want to idle at all. plugged in the TPS and it ran with a crazy idle. High High RPMs. unhooked it and it decreased to dieing idle. Finally got it to start and idle, but it is very high idle. and if it sits too long it doesnt want to start. it is a brand new TPS. also when the truck is running and i hook up the TPS it does the high low idle. any suggestions? Thanks!
Old 02-12-2011, 05:08 PM
toyota4x4907's Avatar
You cant just hook and unhook the TPS and expect it to run properly. The TPS has to be adjusted.
Old 02-12-2011, 05:19 PM
what are the steps to doing so?
Old 02-13-2011, 06:35 PM
I adjusted the tps to what it should be. Now it wont run for more then two seconds.. i unhooked the tps again and now it wont run with unhooked either. at least it ran when it was unhooked. Need help
Old 02-14-2011, 07:10 AM
pitbull_myk's Avatar
start checking your grounds to the body and motor.
Old 06-18-2012, 12:04 PM
ROCKGUY76's Avatar
Did you get your issue figured out?
smthwsn357
05-01-2024 07:28 AM
MO transplant
04-23-2023 11:58 AM
bigjstang
08-25-2021 12:41 AM
Sleaker
08-26-2020 06:03 AM
mskalmus
05-28-2017 07:51 AM
Quick Reply: TPS issue on 22RE
