Toyota Odyssey - 1985, motorhome, small repairs needed
Hello dear community, I was unable to find the negative wire terminal when trying to put the new battery in.
The positive terminal is connected to the fuse box, I do not see where is the negative connected to. Thank you!!
Can someone recommend RV and motorhome mechanics in North California - SF Bay Area, Solano County, Napa County? I need someone who does mobile service for a good price. Thank you!
Welcome to YotaTech!
The negative battery cable should connect to both the engine block and the body (inner fender area right next to the battery on Toyota Trucks)
Since you have an RV version of the Toyota Truck, the RV manufacturer may have moved the location of the grounds to fit their RV, but you should still have a thick cable going from the negative battery terminal to the engine block and from the negative battery terminal to the body.
I really don't have anything as far as a mobile mechanic is concerned. I have not needed one yet!
