torque for the crank bolts
j/w if anyone knows the torque spec for the cranks bolts. i have a 88 pickup with the 22re in it. any help would be much appreciated
116 ft-lb for the crank pulley onto the crankshaft
http://personal.utulsa.edu/~nathan-b...11services.pdf
I'm looking for the main bearing cap torque spec. but thank you for the link. i like having all the secs for everything and i couldnt find them.
anyone know the best place to get them from?
the link he gave you shows 76 ft lbs for the main brg caps
My source at work (online data) shows 76 ft lbs and a sequence
#3 first (the center cap), then #2, #4, #1, #5
Blamalam
03-12-2022 07:34 AM
TJWilly
07-31-2015 02:05 PM
