Timing on a 1994 4runner 3.0 and any important info welcome
can anyone tell me what the timing should be set at on a 1994 4Runner also if anyone has any other helpful info on the 4runners I have open ears anything that i may want to look at or check any issues that i may want to watch for Anything that you can think of will be helpful
this is the first 4runner that i have owned I have had a couple other toyota trucks with 22r but first 3.0 so anyone that can give some advice I welcome to do so
Thanks David
Thanks David
I've got the same 4runner but mines has no power at all seems like its missing or somthin? Any suggestions on parts or things to tweak a lil to get som torque n horses?
You can turn the timing up a bit to squeeze a little more power out of it. Try turning it up to 14 and see what happens, then play with it till your happy. Watch out for pinging. There are tons of 3.0 timing threads out there.
Well I tried th timing it got a little better but I still have this problem where somthin with the voltage or somthin I have no idea but when I press the gas for a split and let it go the rpm goes waaaaaay down lik it's goina die out n idk wat that is...also web I have the truk runnin and I press the unlock for the doors the voltage meter goes down a little then goes bak to normal
