starter trouble,please help!
i have a 94 pickup v6,and once in a while trying to start it,it clicks and clicks,i tried taping it and didnt make a diffrence. also looking more into me starter,the ground wire to the starer looks messed up like not a good connection,could this be the problem?
First, make sure that questionable cable, as well as the THICK cable that goes directly from battery to starter solenoid contact are not broken/corroded and are making good, clean connections.
If that does not work, before throwing parts and money at it, best to understand how the system works.
If you want quick guesses:
If starter (solenoid piggybacked on it should also click) tries to turn (motor does not click), weak battery.
If solenoid, clicks but starter motor does nothing, still possible weak battery or bad solenoid contacts. Search how to replace contacts.
If starter relay (verify location on FSM on my signature) clicks but solenoid does nothing, possible wiring flaw like on 1986-1988 4 Runners (explained on my build thread).
The clicking is coming from the starter it self. It only "clicks" when i cold start it,usually. After a while of trying to start it,it does finally start,and has a hard time stating,like it cranks for a while and then turns over. I'm only 18 and still learning so bear with me.
had similar problem, turned out to be ignition switch
Start here:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Start here:
Agree.
Partially Disagree. If starter solenoid clicks, and starter motor "groans" tying to turn that means solenoid is getting the current necessary to energize it (around 12Amps on 22RE system) and close contacts. That means ignition switch contacts are OK. However, starter motor struggling to turn means it's not getting enough current because of weak battery (likely), OR solenoid contacts bad/high resistance.
Agree: 4Crawler approach is still applicable in order to help extend the life of the ignition switch contacts.
Could also be poor solenoid contact. Too much contact resistance will limit power to starter motor. 4Crawler site also describes repair procedure.
