Speedometer gears not turning.
Ok I did some reading but now I am stuck again.
1: Checked cable connection on dash cluster( good )
2: Removed cable at cluster and tcase it is clean and will manually spin(cable is good)
So now where do I go? the speedometer gear inside the tcase is obviously busted so can i replace this small part or does the tcase output housing have to be opened and parts re built?
Thanks in advance and if there is a write already on this please just link it to me.
Jeremy
Jeremy
Dennisx2
08-04-2015 01:26 PM
altydog
07-28-2015 10:20 AM
