Spark plugs
What is the reason to run dual electrode? Our ignitions do not produce/use enough power for that to matter. I use standard v-power NGK's with a 7 heat range and gap them down to 0.037. I change them every other oil change at that price (1.50 per plug) If you want, i can get you the part number for them since some people run into trouble getting the cooler heat range.
www.sparkplugs.com, and choose the NGK or Denso plugs after typing in all your info, then when checking out put "dodgetalk" in the promo box for 10% off... I just ordered plugs and wires yesterday there
no, not on that site, they are all close to oem I believe...
edit: sorry, I saw cold air induction, but skipped over supercharger... I was just looking for plug recommendation and I know the topic covering superchargers and plugs has come up a few times before... don't remember where though.... spend some time searching, you should come across it
montanatruck
02-26-2017 07:07 AM
defrag4
07-31-2015 10:50 AM
