regaering my solid axle for my swap
hey there I have a 1992 toyota extra cab that I will be doing a solid axle swap on, I already have a 5 inch lift on my truck and it has also been re-geared to 4.88 to match the lift and tires. So basically my question is if I can use the same 4.88 gears out of my IFS diff and out them inside the solid axle that I will be using? Or do i need to get a new gear set for this? Because I know that I can not run the stock gearing since my rear will already be re-geared. If any one can help me out with this i would be very greatful. Thanks guys
Here this will help: http://www.pirate4x4.com/forum/toyot...faq-2-0-a.html
@waskillywabbit thanks for getting a response to me so fast, I was pretty sure that it would not be interchangable but I figured why not ask and make sure. Thanks again for the help.
Cheers
ajetski07
Cheers
ajetski07
Flying91
45
04-11-2024 04:39 PM
Backcountry411
07-24-2015 08:06 AM
scottyg486
07-19-2015 05:34 PM
