power antenna noise
power antenna noise
The power antenna on my 96 4runner has quit going up and down but the motor continues to make a horrible racket..whats the best way to shut it up ..I couldnt find a dedicated fuse for it...thanks in advance..
if you don't want to deal with it being stuck up/down all the time you probably just need a new mast, you can pick one up at the dealership for not too much.
or if you don't want to deal with it at all you could just convert it to a whip, then you don't have to worry about breaking it off on trees or what have you.
I was wondering what should I replace - mast or motor/mast? What is broken there, its must be some stupid plastic thing. How much is the mast in US dealerships (I'm in Canada)?
Another option would be a wip, but how easy it to replace and would I need an adapter for cables to go from one to another option?
it the moter is spinning but nothing is moving -- the "teeth" connected to the mast are broken off so when the moter spins it doesnt catch it
solution:
1) buy new power antenna
2) whip antenna mod (search)
3) unplug moter
solution:
3) unplug moter
from what i know its behind the the fender, i'm sure it goes through the engine bay somewhere though. but i know there is a plug under the fender that you can unplug and shut off power to the moter
terminator
07-27-2015 07:13 PM
