newbee to YT need help with 85 22re
Old 04-01-2010, 04:56 PM
tskinnyp's Avatar
would putting oil breathers on the valve cover really do anything or is that just a waste of money
Old 04-01-2010, 05:50 PM
stryker's Avatar
I had a 86 that I rebuilt the engine in. After putting the engine back in the truck and reconecting everything I had the same problem. Turn the key it would hit and and then stall. After looking for a while I found a main ground wire I had not hooked up. It was in the engine compartment and it conected to the intake I belive it has been a while and rember exactly where it was. Anyway bolted it to the engine and it fired right up. Check for loose wires, might not be your problem but could be. Good luck!
Old 04-01-2010, 06:54 PM
tskinnyp's Avatar
http://s274.photobucket.com/albums/j...0401002206.flv
http://s274.photobucket.com/albums/j...0401002207.flv
theses are links to the video of me trying to start the truck
tskinnyp's Avatar
Old 04-02-2010, 05:32 PM
  #25
tskinnyp's Avatar
if it was the 3 wires that bolt to the efi boltdown yeah i forgot that one to but had already fixed that i did find a 6" ground wire on the ground and cant figure out where it came from to save my life right now i have 3 grounds the efi i mentioned the block to the fender behind the battery and the head to the fire wall are there any others. and is there a thread on how all you guys got ur suspenicion to travel so far man that is awsume id love to have that travel so i can get out of the mud and climb some rocks with the big dogs. woof lol
Old 04-02-2010, 06:15 PM
  #26
krelnydelnky's Avatar
are you sure the timing is on? i just did a swap and it wouldnt start. checked the timing and it was a slight bit off. adjusted it and bam its blowin flames out the exaust. lol jk but fired right up
Old 04-02-2010, 07:31 PM
  #27
stryker's Avatar
Timing could be a problem. I rember thinking that when mine wouldent start.
Old 04-02-2010, 07:37 PM
  #28
stryker's Avatar
Like i said its been a good while since I did mine, but I think my problem came from the 3 wires you mentioned. Wish I could be more helpful.
As for long travel springs I did a SAS on my 86 and had 3" springs from Trail Gear and they were great. Lots of travel.
http://www.trail-gear.com/
Old 04-03-2010, 06:33 AM
  #29
tskinnyp's Avatar
I have I new chain on the way puttin it in today. Then we will c. As for the shocks did you keep the leaf springs
Old 04-03-2010, 01:23 PM
  #30
91_TOYOTA_4x4's Avatar
still sounds like a fuel problem too me but try after u do the timing and find where them grounds go
Old 04-04-2010, 04:52 PM
  #31
tskinnyp's Avatar
replaced the chain checked the fuel all good now the efi. i need to know what setting to put my meter on to check the resistance 20m 2
m 200k 20k 2k or 200
Old 04-04-2010, 04:53 PM
  #32
85-in-va's Avatar
tskinny, im a mechanic from va, private message me with ur address or phone# to see how far away u are from me, maybe i can help u with this, ive been working on yota for about ten years now. BTW im close to charlottesville va, how far away is that for u?
Old 04-04-2010, 05:02 PM
  #33
tskinnyp's Avatar
rockymount va franklyn county about alittle over 2 hours my cell is ********* names paul im up till 12 almost every night call anytime
Old 04-04-2010, 05:07 PM
  #34
85-in-va's Avatar
, not sure if i can help without being there to see it my self but i will give it a shot
Old 04-14-2010, 08:58 PM
  #35
tskinnyp's Avatar
stressed
so i got my truck running again after a new head alota help from 85 in va and some bloody knuckles. as soon as i put it on the road someone passed by and trew a rock through my windsheild. and to top that i was driving it anyway today crossed the river and the distribtor got wet stalled my truck out. now the starter bold is missing trans is got water in it or low on fluid. i dont really know anymore ive bout cracked im so pissed off i dont know. have i led a life so wrong that im going to drown in the tyest luck. wheres chip foose when i need him. like my father always said if i didnt have bad luck i wouldnt have any at all.
Old 04-14-2010, 09:06 PM
  #36
peow130's Avatar
somebody threw a rock through your windshield?
and you didnt call 911?
Old 04-15-2010, 03:12 PM
  #37
tskinnyp's Avatar
no i did a ue in the middle of the road and hunted them down cought up to them forced them to pull over with my 30-30 call a cop i know but they cant do nothing nor the insurance company cause i cant prove that it came from them.
Old 04-15-2010, 03:14 PM
  #38
tskinnyp's Avatar
up date:
i need a new fly wheel and tourqe converter. can anyone help?
Old 04-16-2010, 09:03 AM
  #39
85-in-va's Avatar
u just need 2 convert that thing to a five speed, make a post about it and see if anyone can tell u how difficult it is, i have never done one but im assuming the worst thing would be the peddles. good luck with ur runner, atleast it runs now and you will figure out the rest as u go
Old 04-16-2010, 09:17 AM
  #40
tskinnyp's Avatar
i went through the the work i would have to do n i would actually be simpler to find a 5 speed runner and put the body on my frame. lol but im considering it. and again thank you for comeing down and gettin that thing on the road again if it wernt for you it wouls still be a hunk of metal sittin in my front yard
Quick Reply: newbee to YT need help with 85 22re
