my smokin 82
Old 10-09-2010, 01:56 PM
XNGH_Poh's Avatar
my smokin 82
Hey Folks, New here, and new to my Toyota as well. It's an 82 sb 4x4, The problem I am having is trying to determine why, when and only when I go forward up moderate to heavy inclines it smokes like a chimmney, when I level back out it stops fairly quickly. Things to look for is what I am inquiring about. other than that it seems to run great, Thanks in advance
Old 10-09-2010, 01:58 PM
yoder519's Avatar
burnin oil? motor is probably a little tired. goin up hill=more strain on the engine.
Old 10-09-2010, 02:06 PM
XNGH_Poh's Avatar
I kinda dont think so yoder, I have hit it pretty hard on pavement, no smoke,I mean it is like someone is pouring oil right in the exhaust manifold, thick thick smoke, when I am going up these hills, I am just kinda idling, (out hunting) not at all gettin with it.
but I will keep that in mind
Old 10-09-2010, 02:25 PM
myyota's Avatar
Make sure none of the oil drain back holes in the head are plugged, oil cool pool in the head and possibly run down the valve stem when on a hill ?. Its just a guess, but its the only thing i could think of.
Old 10-09-2010, 03:42 PM
yoder519's Avatar
oooh duuuh. me and my ignernt ideas lol. never considered drivin it hard on flat pavement. wow. see what no snuff does for me?
Old 10-18-2010, 10:52 AM
XNGH_Poh's Avatar
Thanx MyYota, there was indeed a wire seperator in the drainback hole, works way better now. Now, has anyone ever grooved the peaks on the topside of the head ( the ones around the valves) to help with oil draining, Mine seem to be just about submerged in oil.. just a thought
Old 10-18-2010, 12:28 PM
deaddog500's Avatar
The most I have ever done is just general clean-up, grinding the casting smooth (well, smoother anyway), deburring of the return holes.
Just making the path easier has always done the trick.
I have never groved the peaks off though.
Old 10-18-2010, 12:37 PM
XNGH_Poh's Avatar
well thanx anyhow
shazaam
35
09-29-2004 06:03 AM
MODZILLA
08-28-2004 11:05 AM
guinness
24
06-18-2004 06:28 PM
Quick Reply: my smokin 82
