My 1995 toyota 4runner wont turn over!
Old 08-26-2011, 04:54 PM
454montecarlo's Avatar
The 22re that was in it blow up, so I replaced it with an older 91 22re, both are 4x4 and M/transmission. the wireing is just about the same in the two, just the oil sending unit and alternator are different plug ins and injector wire colors haha. when i put the battery post on.. the starter starts clicking and smoking. if i take the starter off engine she will start turning if i put the battery post on. help me please...
Old 08-26-2011, 06:57 PM
myyota's Avatar
Swap in the alternator and oil sending unit from the old engine and check all of the wiring to make sure you have it properly hooked up.
Old 08-26-2011, 07:07 PM
did it all. everything looks great just making the clicking sound!
Old 08-26-2011, 07:45 PM
4Crawler's Avatar
Is this the original starter or the one from the new engine? Sounds like it has the solenoid stuck on if the starter spins (or tries to) with just the power post connected. Normally you also need to have power to the solenoid terminal as well.
Old 08-26-2011, 10:38 PM
it is the original starter. i will try sum more things tomorrow!! don't make sense whats wrong!
vasinvictor
01-20-2016 12:39 PM
Bamripzit
07-19-2015 01:17 PM
Bamripzit
07-13-2015 07:21 PM
JaredL
06-16-2015 04:47 PM
95Runner
06-09-2002 09:08 AM
Quick Reply: My 1995 toyota 4runner wont turn over!
