to much negative offset
Old 07-06-2011, 12:13 PM
F00PDA3W00P's Avatar
now my question is i have an 88 lifted 6 inchs and have 35s on with 410s ok ifs up front and i rub on upper A's can i put the 1.25" spacers on front to make the clearance i need
Old 07-06-2011, 01:30 PM
MudHippy's Avatar
I'd say there's a high percentage chance it'll work. A good way to test out the hypothesis would be to put the front of the truck on jack stands. Then loosen a wheel by removing the lugnuts by 1" or so. Steer the tires to the points where they make contact and see where you're at. That's what would do. But with 3.5" backspacing 15x10s my 35x12.5s don't rub nothing steering/suspension wise(almost the idler arm turning hard left though...but by roughly a hair's breadth does the pass side tire not touch it...call it ~3-5mm).
Old 07-06-2011, 01:36 PM
well i put them on and the tires rubbed on upper a's bad so i figured i would just put spacers on oh tire size is 35 12.50 16
Old 07-06-2011, 01:44 PM
MudHippy's Avatar
Right, so no hydraulic jack and jack stands then.
35 12.50 16? Odd...who runs those? Beats me!
Good luck!
Old 07-06-2011, 02:15 PM
sorry 315/75/16
Old 07-06-2011, 02:53 PM
BoredOutnJackdUp's Avatar
I had 35x15.5 boggers on my 83 and they rubbed on my leaf springs. so i threw some 2 inch wheel spacers on it they worked like a dream. didnt have a problem.
but if your worried about it not being enough get a little bigger to be safe.
suppra87
07-15-2021 05:15 PM
Bourbonblues
12-15-2017 05:43 PM
JHalcyonM
09-14-2015 01:10 AM
theduck21
09-10-2015 07:01 PM
kouki420
09-02-2015 11:42 AM
Quick Reply: to much negative offset
