Motor swap or regearing?
Old 04-27-2010, 09:51 PM
  #81
yotaman85's Avatar
OP. the best thing you can do in my educated opinion, is to get bigger tires, upgrade your injectors and make sure the motor is pulling air as easy as possible. I explained in an earlier post why a bigger exhaust isn't too important without a turbo.
to make it easy, a diesel loves compression and fuel/intake flow.
  #82
peow130's Avatar
Nonono
He should gear to a stock feel.
THEN do performance mods.
He keeps the powerband in the speed areas he wants, but he gets more power.
I'd gear as well as performance mods..
Old 04-27-2010, 09:55 PM
  #83
Csbauer's Avatar
I will have to agree with Yotaman 85 on this. get the tires, and invest in the mods that will add horsepower... turbo with a larger exhaust added at the same time, larger injectors, and intake.
Old 04-27-2010, 09:57 PM
  #84
2DoorRunner's Avatar
OR we could draw straws, and whoever wins gets his truck
Old 04-27-2010, 10:01 PM
  #85
Csbauer's Avatar
I say nay... straws is too hard... im too far to do this... gah exams are tomorrow or today i should say... i will be back!
Old 04-27-2010, 10:04 PM
  #86
Yeah im hitting the sack, getting up in 6 hours.
Old 04-27-2010, 10:10 PM
  #87
peow130's Avatar
hahaha suckers.
i'm so glad i don't have class till 1 tomorrow.
Old 04-27-2010, 10:49 PM
  #88
Csbauer's Avatar
haha my exam isnt till 8ish... now i just cant sleep cause im dreaming about my toyota lol
Old 04-27-2010, 11:10 PM
  #89
yotaman85's Avatar
Originally Posted by peow130
*sigh* You're not understanding it though.
ok...
Old 04-28-2010, 08:04 AM
  #90
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Originally Posted by 2DoorRunner
csbauer-Exactly, good conclusion of the thread. Already admitted i was wrong because i misunderstood what we were talking about (makes me feel like a newb haha).
I think he got in trouble. The post where he called me a bit&% was edited.
I most certainly did NOT call you a b.... I said, "it's ppl like you that b.... and complain... about a Diesel..."
And I edited it b/c it was soapbox... But the truth... You don't see any Diesels coming to Merica, do you?
And for the record, gas engines bring the suck
A friend with a 25mpg Bj60 spends .20 a gal on BioDiesel... And I'm jealous to the point I want to start making "BioGas"
some copper wire... how do you make a still again?
"You can smell the whiskey burning down Copperhead road..."
Old 04-28-2010, 02:58 PM
  #91
Trasher's Avatar
Originally Posted by eddieleephd
He said he had 31" and it was already weak which tells me he had like a 28" wheel to start and this is why I say I need the door code to say!!!
We must start with a stock setup then manipulate the rest!!!
The factory setup is 205 R16, see below:
http://www.shooter.hu/hilux/platex.jpg
Old 04-28-2010, 03:33 PM
  #92
Trasher's Avatar
Originally Posted by Csbauer
Then again i just love the sound and torque from diesels
I bought this truck about 1.5 years ago and love it. I've a stable 21 MPG (11 litre per 100km) fuel consumption on- and offroad. Some guys feed these engines with cooking oil + diesel mix without any ill effects (cooking oil up to 70-80%) for lower costs and a little extra performance.
Old 04-28-2010, 04:21 PM
  #93
peow130's Avatar
Lol good lord.
Okay.
It would certainly help to get the axles geared to 4.88's, or even 5.29's.
The recommemded gear change from 28-33 is like 5.85..
Old 04-28-2010, 05:21 PM
  #94
Oh alright, i got ya. I missed the "that" when i read it so i thought you were saying people like that b----.
Biodiesel is awesome, best part is that it smells like french fries
My dad runds it in his suburban, my step mom has a diesel bug and mercades, and my sister has an old mercades, thay all run on biodiesel. I guess im the out cast haha
Old 04-28-2010, 06:16 PM
  #95
Csbauer's Avatar
That is amazing... small truck but tows a mountain. I would love to be able to do that modify the engine for a turbo, and just go for miles getting great mileage.
Old 04-28-2010, 06:42 PM
  #96
eddieleephd's Avatar
in the US, the range of tires available in the 205 R16 size is limited. ... The diameter of these tires is very slightly larger than the 29 inch 205-R16, ...
so we will start here
calculator says new gears=5.19 high gears=4.72 low gears=5.66
5.19 for 2wd
now the reality is that the tranny is not designed to run that much power through that set of gears on that large of wheel !!!
Even though some of you say that "YOU WOULD JUST DO POWER MODS"
!!!!!!!!!!!!DOES NOT MAKE IT THE RIGHT COURSE OF ACTION!!!!!!!!!!!!!!
SIMPLY PUT YOUR SUGGESTION COULD CAUSE HIM A TRANNY REPLACEMENT!!!!
The right way is to regear for the wheel then do power mods!!!
have you ever heard not to haul in OD well if you did not regear this set up then you would cause this same effect thus blowing at least the 5th Gear out if not 3rd and 4th as well!!!
Aone can talk about what they would do BUT I will say that done correctly is to regear and then do power mods!!!!!!!!!!
The rest of you can think what you want about what I just said but I do have a 5th that needs replacing soon!!! From too large of tires!!!!!!!!
Old 04-28-2010, 09:57 PM
  #97
Aint gonna swear to it, but could be an R series...
I'm pretty sure the Lj's got them... Why not the Lux? He's also got (pretty sure) factory straight front axle... Who knows how a not for US Hilux is built?
Eat yer hearts out guys...
http://www.4wdonline.com/Toyota/LJ70/Bundera.html
"diesel: (LJ70...)
* 2L 2446cc diesel 4cyls 2-valves/cyl sohc
* bore: 92mm, stroke: 92mm, c.r.: 22.3:1
* power: 72 HP at 4000rpm, torque: 115 Ft-Lb at 2200rpm "
"First developed as the light duty of the 70 Series, in November 1984. Available only in short body, and there were options for soft top or hard top (metal top). Names like Land Cruiser II, Land Cruiser, and Bundera were made for these 'Light Duty' Land Cruisers. There were 3 engines options with gasoline engines, 2.4 L (2366 cc) 22R engines and 2.4 L (2446 cc) 2L and 2L-T diesel engines. Transmission for the gasoline engine is G52 type while the diesel used the R150 and R151 type. These were the same engines and transmission used in 4Runner, in cooperation with Hino."
Old 05-03-2010, 05:04 PM
  #98
peow130's Avatar
I know in australia the hiluxes come with factory straight axles up until 1995..
Old 12-31-2010, 12:43 PM
  #99
camo31_10.50's Avatar
why didn't anybody tell him to swap to the much more powerful and efficient 3.0L turbo diesel?
Old 01-03-2011, 06:43 PM
  #100
truckman1966's Avatar
2doorrunner, what engine is that? and where did you find that pic?
Quick Reply: Motor swap or regearing?
