I need help!!! No power 89 22re pickup - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-24-2009, 05:53 AM   #1 (permalink)
Exclamation I need help!!! No power 89 22re pickup
My 89 toyota 4x4 22re last night i was messing around in the snow spun out then drove for about a mile then lost all low end power??? It will not get up in speed less if your foot is to the floor.
tuffyota90 is offline
Old 10-28-2009, 07:37 PM   #2 (permalink)
check your air flow meter mine had a similar issue and the flap was totally loose inside there should be resistance to open. also the o2 sensor could be causing your issue after i replaced my airflow meter the truck was sluggish in midrange i unplugged the sensor and it ran great so i replaced the sensor and the truck drives great
craigory1983 is offline
Old 11-06-2009, 07:52 PM   #3 (permalink)
if not air restriction coming in then fuel restriction. Fuel filter is my best guess from your description of the symptoms. Run a can or two of fuel cleaner through it just for kicks and see if you notice any help.
No codes mentioned(?) cat smelling? any weird exhaust or gas odor?
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Fact. Rr. Locker/Diff Breather Ext.
Old Man Emu lift springs- 881 fronts/890 rears
O/M/E shocks- N91s fr./N86 rr.
All Pro Off Road welded sliders-prevent body damage!
ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s
Redline Tuning hood struts/Bushwacker Extend a Fenders
all my photos are over on Facebook now-I gave up on photo hosting sorry....
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Old 11-06-2009, 09:34 PM   #4 (permalink)
Kiroshu's Avatar
Any lights on? Trouble Codes? Is there a check engine light on while this was happening.. if so i suspect airflow... check resistance of air flow meter and make sure its in spec... if any of it is not in spec it needs replacing... check for fuel... spark....
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Tags
22, 22re, 22res, 89, air, bridge, flow, meter, o2, pickup, power, sensor, sluggish, tech, toyota, unplugged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
