Hydrolysis!
Hydrolysis!
I've got this red button on my dash which is currently hooked up to my horn, which is dumb. I'm gonna put that wire back to normal but I want to use this red button...
Hydrolysis is basically an electrical system that converts water into hydrogren by use of electricity. I did a quick search on the subject and nothing really came up. Since I've got plenty of room in the engine bay here on my 22re I was thinking I could set up one of these machines. I would run the electricity off the alternator and have the device create some hydrogren and then let the hydrogren flow into the intake somehow.
Some questions, do hydrogren and gasoline burn at diff temperatures? If so, will this create possible detonation/knock/something bad? How rich of a mixture could I get away with? Will I have to tune my ECU to account for this new fuel? And finally, will I see any mileage/hp gains from running a gas/hydrogren mixture?
I kind of had this vision where I would hop on the freeway, hit the switch and let the truck cruise creating its own fuel
I can't help but think it sounds a little too good to be true. Not sure of the ins and outs of the build but basically it takes a bit of tweaking to get it all working right. You have to find the balance between how lean you run your fuel to maintain the original performance of the vehicle.
He told me parts cost about $100.
There are at least 2 LOOONG threads discussing it on here.
NOBODY has presented statistically valid data to show any improvement to my knowledge.
The math shows that it probably violates the Laws of Thermodynamics.
If you are talking about the same system we were on the Subaru forum, it's changing the air density / composition, throwing the air testing sensors off, it leans out the mixture to compensate, thus saving you gas. Knock Knock? How long do you think that will last before you scatter you motor?
Quote from another forum.
"The only way to improve fuel efficency is to burn less gas. Wow, what a concept. Lets repeat. Want more MPG? You need to put less gas in the engine. The way you do this is leaning it out. It's the only way. Too much air and not enough hydrocarbons (those wonderfully explosive things that drive the modern world) = a short lived engine."
Research I have done says that the supplemental hydrogen makes the burn more efficient, therefore requiring less throttle because you get bigger bang from your fuel. Makes sense if it works. Wanna try it myself. Made a small generator, and drawing 15amps, apply lighter, get loud bang. Might actually work.
http://www.searcypress.com/fuelcell/index.html
Check out the "$10 fuel cell video" if you are interested. Its kinda long
If anyone knows their average mileage they could test this really quick. The video says $10 will get you one of these. I wouldn't recomend it offroad..
In terms of efficiency, the combustion process is VERY efficient at turning the chemical energy in the fuel into heat. Unfortunately, the engine is not very efficient at turning that heat into kinetic energy.
In that video their fuse is rated at 40 amps so the amperage they designed the machine to run at never exceeds 40. What kind of voltage or amperage does an alternator put out? They also said something about 7 watts of power, I forget.
For one no machine is even close to 100% efficient, so how do you get the engine to somehow split water atoms and get hydrogen. Yeah, 15 amps, you all realize one of the main problems with hydrogen fuel is that it requires massive amounts of energy to do this?.?. thereby somewhere in the power chain this clean energy is not really so because the fuel was produced with electricity from coal/fossil fuels.
Well, what's the resistance? I know the voltage and the current, power = voltage * current.
See, here's what pisses me off about this deal - no REAL data. Where did they get 8 MPG? On one tank over another? Was one tank city and one tank highway? One with flat tires? I am open minded about this process, but nobody has shown me data I can use to make a scientific decision. There is considerable variation in normal gas mileage measurements that need to be accounted for. I would like to see (at least) 10 tanks without the system and 10 tanks with it, a variety of driving in both cases, tire pressure kept consistent, no drafting or other cheating.
Ok so with their setup the machine pulls 25A at 12v volts off the alternator. They also claim 8mpg increase on their chevy 1500.. so thats like double
