head gasket failure - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-23-2007, 08:50 AM   #1 (permalink)
balverson's Avatar
head gasket failure
I had a head gasket failure on a 2.7 i4 96 tacoma. The head, per the machine shop, was badly warped (.040 in. to resurface) and was, at that point, unuseable. This had been a long ordeal and the shop has still not completed the repair-and VERY,VERY expensive. I was loosing coolant and it was determined that it was leaking in no.1 cylinder. All of that for this-
what other that overheating could have caused the failure. Really don't want to do this again.
balverson is offline
Old 08-23-2007, 09:08 AM   #2 (permalink)
rdlsz24's Avatar
Send a message via AIM to rdlsz24
Head gaskets can fail on their own over time because of the head being made of aluminum and expanding and contracting.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd)
Rancho lift w/ 33x12.5x15 tires & 5.29s
rdlsz24 is offline
Old 08-23-2007, 09:47 AM   #3 (permalink)
Stop the presses.....
The head can be easily repaired by heating it to a temperature that softens the aluminum and then clamping it flat to cool. Racers have this problem often so the repair is commonplace....just got to know about the fix.
One has to ask themselves how a head, under tremendous clamping forces can warp? My conclusion is that it was they way from the factory. Is Toyota checking every head installed..............NO.
Why is Toyota plagued with head gasket problems and Honda is not! See previous statement.
I fixed my 3vz 3.0 V6 by making my own copper head gaskets after watching Toyota release several different head gasket designs in an attempt to fix the problem. I alsp purchased some high tensile strength head studs and nuts to replace the *#$%@^ junk headbolts Toyota put into those engines. Torqued them to 60 ft-lbs (short one to 45) and no issues after 20K miles. Amazing.....
Get your head heated and made flat. Get some new head bolts and see what is available for gaskets. Engine Builder in Washington State is a good resource for parts and advice. He is an engineer and offers really good parts at a reasonable price.
$0.02
SEAIRESCUE is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Head gasket? Kaydon 86-95 Trucks & 4Runners 12 06-16-2007 02:01 PM
Head Gasket MAD 4Runner 86-95 Trucks & 4Runners 12 10-03-2006 06:38 AM
Cracked Head or Blown Head Gasket? StevenR Maintenance & Repair Archives 5 06-14-2005 10:49 AM
head gasket? John79 95.5-2004 Tacomas & 96-2002 4Runners 4 03-26-2005 06:03 AM
Replaced Head Gasket, but not Head Bolts -- How bad is this? The Rusty Gear 95.5-2004 Tacomas & 96-2002 4Runners 14 09-13-2004 08:03 AM
2009 InternetBrands, Inc.
