Driving in 4 Wheel Drive
I'm not a newb but have a newb quesiton so here it is.
I went wheeling the other day and have a couple of questions.
Can you engage the transfer case in 4 wheel drive low or high with out having the front wheels locked? Will it hurt my rig in any way?
Thanks-Blake
Thanks-Blake
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
you're just turning the front shaft, diff and axle shafts?
other than drag and load the engine will overcome by using more gas, I don't see the point...
Yes, you can use 2L... I do it all the time... But watch how you cut the wheels.
If the hubs are not locked, you can not shift on the fly.
If you come to a stop, shift, and then go on, though, it won't hurt the truck any ... until you get stuck and really need the front wheels driving ...
elblako91: No, you can't hurt the truck at all by doing so. All that's going to happen is your front driveshaft/diff/axles will spin with no load on them. It doesn't really matter to them if there's a wheel on the end or not.
Poncho0206
07-10-2015 06:21 PM
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
