changing out rear ends
Old 02-08-2008, 08:24 PM
toydan's Avatar
I want to change out the rear end of my 86 toyota 2wd 22r(?not sure the difference) with something with a better gear ( I.E. a pozi with 3.43 gears from an explorer or something like that). Now its not a rock crawler or off road truck just want to go faster and launch better, its sort of becoming a drag truck and because it surprises everyone. So any help you can add/ also any idea for the best cam and heads to put on please let me know
Old 02-08-2008, 08:49 PM
Staff
DeathCougar's Avatar
What gear ratio are you looking for? Toyota made many from 3.42 to 4.10 that will fit in the 2wd housing.
Old 02-08-2008, 11:04 PM
toydan's Avatar
I am looking for a good launch so like 3.43 gears but a pozi would be nice and I need a new diff due to it being damaged so i was trying to think of what would work. What is the stock gear ratio for the 86 2wd?
Old 02-09-2008, 08:06 AM
Staff
Toyota didn't make a posi that fit in the 2wd trucks. But they did make a 3.42 gear ratio rear end.
There were 7 possible gear ratios for the 86 2wd truck; 3.07, 3.42 (turbo 2wd) , 3.58, 3.73, 3.90 (one ton single or dually) , 4.10 (one ton single rear wheels) and 4.30 (one ton single rear wheels)
IIRC the one ton dually used an 8" diff, VS the standard 7.5" 2wd.
Old 02-10-2008, 12:31 AM
toydan's Avatar
so the half ton is most likely a 3.07 gear? and can the gear ratios be changed? and an aftermarket pozi put in
Old 02-10-2008, 05:35 AM
Brenjen's Avatar
Couldn't you slap in a locker?
Old 02-10-2008, 08:23 PM
toydan's Avatar
I dunno can I
Old 02-13-2008, 04:13 AM
Brenjen's Avatar
I would think so. Find out what ratio you have & check Richmond Gear.
Old 02-13-2008, 02:33 PM
91 4Runner's Avatar
Swap a whole 8" axle and 3rd member in and add a locker - but you may be limited to 4.10's and lower...
Old 02-13-2008, 02:44 PM
jjrgr21's Avatar
just get a whole 8" rearend from the boneyard, then you can do what ever you want. you have a 7.5" rear now, so not a huge selection for gears and i don't think any LSD's or lockers
icentropy
09-16-2020 02:47 PM
icentropy
07-11-2015 07:21 AM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: changing out rear ends
