Battery cable broken... fix??
Okay so I'm going out on a limb here and asking a question that might be dumb but heck, I'll ask it.
For sometime now I have had problems starting my runner(1990 4runner 4x4 v6). Anyways, I had the battery replaced and the problems seemed to end. Well a few months ago it happened again, no start unless I got a jump(Which quickly started each and every time). Well I figured I would check on it myself and this is what I found:
The Thick wire that goes to the positive was cut/rigged. As you can see from the picture I posted/found on here. So it doesn't have the big metal bracket if you will that attaches to the terminal(As I have circled here with my keen skills at MS Paint). Sooo after all this, my question is, can I replace this wire or is there a way to purchase that metal piece so that I can install it to the terminal?
Also, without that metal piece attached to the thick wire the install makes it difficult due to it being shorter (Because of the broken/non-existant metal piece)
strip the wire back some get a couple copper lugs take some solder fill the inside of the new triminal about half way now hold it with some pliers heat it with a torch tell the solder melts then jab the wire in and hold it for a few secs
apparently you read my thread!! the same cable i used in that thread should be a great replacement for that stock broken wire... just make sure you get it long enough..
i bought new terminal ends and just cut my old canles back a few inches and spliced the cables together and soldered them together and then used shrink tubing and electrical tape. its worked great for like a year..
jasonty
41
12-23-2018 01:00 PM
montanatruck
02-26-2017 07:07 AM
altydog
07-28-2015 10:20 AM
CanRunner
07-20-2015 01:29 PM
