Arkansas 4runner, running rich?
I'm new to the forum, and a new owner and proud owner...but its diminishing...of a 95 4runner 3.0 v6 4x4. The thing ran great for the first few months I had it, but now its running really rough, with hardly any power. I've read up on a few things to check, but i'm running out of time. I work full time and go to school full time. I did a seafoam tune up, but that did not fix it... i'm wondering if there is a problem with my injectors?
Here is what I've done so far.
-Ran codes which pulled DTC codes 42 VSS Circuit & 43 Starter Signal Circuit
not that long ago i replaced a bad speedo-cable (speedometer works)
-I ran compression test on the spark plugs on the air intake side (easiest to get
to ;-) (it ran 120psi on all three)
-pulled spark plugs and they look cleanish
what I'm planning to do today before i have to go to work. check spark on plugs, and run a few ohm tests
Here is my questions:
Does anyone know of a trusted mechanic thats not going to rape me for all my money (which is very limited) that would diagnose and maybe fix if I can't do it myself (I live in NW arkansas (gentry to be more specific))
What are somethings that I should run my ohm meter on? cold start injector? egr?
please any comments and suggestions and pointers are greatly appreciated...
btw, love the forum, i have got a lot of useful info from here, but i have now run into something thats not been as easy to diagnose and tackle
the hoses look like they are new, looks liek the previous owner replaced all the hoses, but yes, i did use the propane trick and ran it around all the hoses with no change in RPMs; I don't know how timing could have gotten off, i literally went in to work, came back out to leave and it was running like crap...nothing happened before that, really. every once in awhile it would have a rough start idle, but i'd turn it off and start it again and it went away, now its not at all...could it be a fuel pump? how do I check the fuel pump?
I just replaced fuel filter today, and while it was off, i cranked the engine, and fuel poured out quite nicely! But yet, no go on the problem, still idles crappy, and drives with no power.
If no one pops in with a good mechanic around here, i'll probably just wait till i have spring break, and take the intake manifold off and replace fuel injectors, plugs, wires, PCV valve. anything else that would be good to replace while I have the intake off?
thanks in advance!!
thanks in advance!!
87blyota
07-01-2015 05:26 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
