99 runner front end clunk
My 4 runner has a clunk in front end not in suspension but when truck is rolling on flat road. Acts like a CV axle is bad but don't do it when I turn and is only about every third rotation of the tire. Don't change to put it in 4 wheel drive. No ripped boots or leaks! 115k all stock. Don't do it when u roll the tire when it is on stands. Anybody head me in the right direction? I'm thinking axles or front diff!
Bad wheel bearing under load, upper or lower ball joint worn out, loose sway bar end, worn out steering rack bushings, blown shock, something simple loose........lots of areas to look at.
truckmike26
10-26-2015 05:10 PM
YotaGreenhorn
06-27-2015 07:00 AM
