94 22re valve cover gasket
Old 12-18-2016, 01:11 PM
94 4bangin's Avatar
Hey guys "newbie" here. I have a 1994 22re pickup and I'm going to be doing a egr delete and i figured id adjust the valves at 250,900 miles. Now i looked up a new valve cover gasket on LCE here:http://www.lceperformance.com/22R-22...-p/1024057.htm Now my real question is what is the 9 bolt or 7 bolt gaskets for. I've seen valve adjustments and new valve cover gaskets on older model 22re's but never saw the 3rd gens with the replacement. If you could tell me what the 9/7 bolt gaskets are for that'd be great, Thanks guys!
Old 12-18-2016, 07:14 PM
thefishguy77's Avatar
Why EGR delete? Just asking because it won't give you any power or millage in the 22re. If the EGR is plugged then you can clean it.
As to the valve adjustment you just need the silicone gasket new 1/2 moons and the new rubber caps for the 4 nuts on top of the valve cover. Don't over tighten those rubber caps and make sure you put a dab of rtv on the 1/2 moons before you put the valve cover back on. Easy job.
Check your timing chain guides while you have the cover off as well. The drivers side has a tendency to break and allow the chain to where a hole in the cover.
Old 12-19-2016, 09:22 AM
94 4bangin's Avatar
Yes i know, I'm doing the delete because the valves are sticking open i believe. I figured i would just delete everything that way i don't have issues further up the road. About the gasket, did you click the link and look at the 7/9 bolt gaskets? I would like to know what those are all about
Old 12-19-2016, 11:11 AM
I have never used their gaskets. I have just used engnbldr or a parts house gasket. There are some that putt all possible gaskets in the kit. Carb, efi, turbo. If your unsure call them and ask.
Deleting the EGR can cause you to trip CEL lights on occasion. Just make sure you don't ignore your CEL if it's flashing make sure and check it.
Here is one example
http://board.marlincrawler.com/index.php?topic=78262.0
Old 12-19-2016, 11:51 AM
94 4bangin's Avatar
Okay thanks. I did watch the LCE youtube vid on the EGR delete and they did tell you to put a resistor on the plug the valve was plugged into to avoid codes. I guess i will order this kit and just keep the excess gaskets.
Old 12-19-2016, 01:30 PM
Just one last question. Does your state require any sort of visual inspection. If so it will fail
Old 12-19-2016, 02:49 PM
old87yota's Avatar
I just used the chat feature on LCE's website. They said the 7 or 9 bolt gasket is for the oil baffle on the under-side of the valve cover. Most valve cover gasket sets do not come with them so they usually don't get replaced. I would not worry about the gaskets with what you are doing.
Old 12-20-2016, 02:05 AM
Co_94_PU's Avatar
I'm to lazy to go dig it up but iirc the ECU alters fuel and timing based on the egr in 2nd gens hence the sensor that verifies it's working the older generations don't have.
Old 12-20-2016, 05:35 AM
94 4bangin's Avatar
No theres is no visual inspection. Okay thank you thats what i needed to know. LCE also has a gasket that isn't molded that i think is maybe a lil cheaper so i may just go with that.
