89 FJ62 Oil Pressure Issue
Old 04-24-2009, 09:29 AM
contact.tate's Avatar
Hey guys, newbie here... I have an 89 Fj62 w/ 150K, the oil pressure hangs at 60lbs, but I am not seeing oil spray inside the valve cover when I remove the oil filler cap. I read ealier that the 2and 3f engines aren't known for spraying oil, but rather dribbling it in the top end. Is this true? The engine runs like a top. Any suggestions or comments are greatly appreciated. Thanks!
Old 05-05-2009, 07:40 PM
nakman's Avatar
If it's running well, and has always run well with similar readings, then I'd guess there's nothing to worry about. if you want more and better advice, then I'd suggest tossing a post up in the 60 series wagon section of ih8mud http://forum.ih8mud.com/60-series-wagons/ but good to see another Cruiser owner here on Yotatech!
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
88yodabasket
07-13-2015 01:32 PM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 89 FJ62 Oil Pressure Issue
