88 22RE overheating
88 22RE overheating
There are many posts about this problem but I have not seen mine. Only after driving several hours and if I stop for gas or shutoff the truck for a few min the temp starts climbing up.
The rad seems to be boiling and the overflow fills up. If I drive the truck with it hot it goes back to normal temps in a mile or two.
I have a new radiator, thermostat, and hoses. Any ideas?
If that doesn't do the trick, and it very well should, look into getting a "sniffer" test to check for exhaust gasses in the coolant. Mine was doing the same thing and after replacing all the cheap parts like the car, and t-stat i found a leaking head gasket was my culprit. Not saying this is your problem so definately knock out the cheap stuff before you go onto the head gasket.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
My 91 would do that and my 84 does on hot days...
My advice is to get a 3 core rad out of a V6. One out of an AT truck will work as well...
3 core and T-stat then call us back if symptoms persist.
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Jeffreynmandy
07-18-2015 08:26 AM
the1998sr5
07-16-2015 06:20 AM
