87 p/u 22re 4wd 5 speed trans ?
i just bought the truck the other day and im new to yotas.. everything was fine, and as my luck goes, today the trans started making a horrible sound.. almost like a diesel when the rpms are real low.. raspy, grinding kinda sound almost, but its quiet and normal in 4th gear.. im almost positive its the tranny, but just hoping for a little insite before i go buying one.. thanks in advance
heres a video i tried to take today.. id say it was a failed attempt, but its all i got at the moment.. idk how well you can hear it either.. but its going from 4th gear to 5th.. 1st, 2nd, and 3rd gear make noise but its bearable, 4th is quiet as a mouse, and 5th is terrible..
View My Video
View My Video
Your symptoms sound like mine.
Fourth is ok because its a 1:1 drive ratio....no gears to grind.
I ended up swapping in a used one with fewer miles and it sounds great. Search for "philbert's 1987 4runner w56 swap" and you can follow my symptoms and swap.
Good luck!
Good luck!
quick trans question
im looking for a trans for my 87 p/u 4wd, found a guy who has one laying around, but doesnt know which trans it is or what it came out of.. what can/should i look for while looking at this trans to see if it will fit my truck? thanks in advance
MMA_Alex
25
04-18-2017 05:07 AM
TokyoD23
07-12-2015 06:01 AM
Poncho0206
07-10-2015 06:21 PM
