22r timing chain wear, pics
Old 12-11-2013, 08:18 PM
twoyotas86's Avatar
Im currently swapping engines and im curious about the amount of play in the timing chain on the 22r im swapping in.
thanks.
Old 12-17-2013, 09:31 PM
twoyotas86's Avatar
Come on somebody! chain guides are still intact.
Old 12-17-2013, 10:05 PM
cman1's Avatar
you are going to have play , your tensioner works off oil pressure,as long as the guides are intact you should be good.
Old 12-19-2013, 02:48 PM
83's Avatar
Yeah the chain gets tighter once the oil pump is running.
cman1 is right. If the chain were too loose, you'd see major grooves in the guides, or they'd be gone completely and lying in your oil pan.
Old 12-19-2013, 08:03 PM
skoti89's Avatar
no grooves= probably still good
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 22r timing chain wear, pics
