1988 22RE Headgasket replacement gone off course...
Old 07-24-2009, 11:21 AM
sparx483's Avatar
I am currently working on my father in laws 1988 Toyota pickup that has a 22re motor that has not been kept up very well... I have already pulled it apart and am now in the process of putting it back together. I made the mistake of not documenting where everything went(i thought i did, but i didn't...).
I am having several issues any help would be much appreciated.
I am having trouble locating the spot where the larger banjo bolt goes from my EFI...
All material I have found that shows the vacuum lines shows the VSV only having 2 hoses with a knob looking thing on one end. I have a spot for a third where the knob looking thing should be...
on the bottom side of my intake manifold where it connects to the head, about at aprox mid-way back, there is an opening for something with 2 bolts to attach to it, I have no idea what goes there...
HELP!!! thanks!
Old 07-24-2009, 01:48 PM
ohyeahcrx's Avatar
Is there any way you can take any pictures of what you are having issues with?
Old 07-24-2009, 02:31 PM
sparx483's Avatar
yeah. I will try to get some up within the day.
Old 07-24-2009, 05:17 PM
olharleyman's Avatar
I think can't be sure but I think if it BANJO bolts like your saying they go to the fuel rail and head from here
to here
not sure these are the ones you are talking about but i just put my on and these are the only BANJO bolts I can remember putting on.
WOW sorry I just re read your post and I am recovering from a minor brain fart but I now have the correct photo's for you , the BIG BANJO bolt is the feedline to the bottom of your injection set up here
Old 07-24-2009, 07:53 PM
sparx483's Avatar
Thanks olharleyman... that's the one! Very clean engine by the way.
Old 07-24-2009, 08:07 PM
Thanks just about done doing to complete rebuild first timer and doing all myself except the machine shop work of course and using only the motor I tear down and stuff I find on here to do it really simple if you have any kind of wrenchin back round but not saying it's some thing anybody could do the way i am but I think anyone with a good manual could pull it off.
Old 07-24-2009, 08:09 PM
sparx483's Avatar
This is the layout of the vacuum lines that i have been working off of from my chiltons...
Here is the VSV that i was referring too.... Am i missing a vacuum line here or am i just missing a cap?
Any help on this would be much appreciated.
Old 07-24-2009, 08:27 PM
sparx483's Avatar
This is the best pic i could get of the opening on the underside of the intake where it meets up to the cylinder head. sorry about how tight/blurry it is, it was the best i could do while snaking a camera back there because the intake is already bolted up and I really don't want to pull it all off if i don't have to.
Old 07-24-2009, 08:55 PM
Plumbrbob's Avatar
HELP!!! thanks!
is it the coolant lines for the heater core?
does it mount up to the head?
Old 07-24-2009, 09:00 PM
Can you get a better pic and wider angle and I will go out to the garage and see if I have mine hooked up and maybe we can get yours done that way.
is it all the way at the back of the head? If so you should have a pipe that runs to the drivers side like this
For some reason my paint will not except jpg files but if you look to the right where the pipe hooks up there are two of them are either one of these the ones your referring too?
Old 07-24-2009, 09:09 PM
Just ran out to the garage is it any of these 3?
Old 07-24-2009, 09:18 PM
sparx483's Avatar
looks like its the second one... That has to be the pipe that connects to a hose that runs through my firewall then. i will have to go take a look when it gets light out.
Old 07-24-2009, 09:27 PM
OK glad to give you a hand via here tomorrow if you still need it I will be gone for the most part of the day but evening I will be back and can get as much info pic wise for you you need if I have got that far on mine.
Old 07-24-2009, 09:29 PM
sparx483's Avatar
the only thing left is that VSV... i see in your pic that yours is still wrapped up in blue tape, but i can tell it has the knob or cap, i'm not sure which it is. Hopefully just a cap.
Old 07-24-2009, 09:32 PM
which pic and I'll look
Old 07-24-2009, 09:33 PM
sparx483's Avatar
the shot showing your entire motor from behind.
Old 07-24-2009, 09:36 PM
The one hanging low?
Old 07-24-2009, 09:42 PM
sparx483's Avatar
Its the brownish colored thing sitting on your valve cover that has some blue wrapping on it.
Hopefully the pic will show up now.
Old 07-24-2009, 09:52 PM
If it's the brown one on top of the valve cover I will be loading up a pic in a sec and ashow you where two lines run to.
Old 07-24-2009, 09:57 PM
Here's the pics is this the correct one?
Quick Reply: 1988 22RE Headgasket replacement gone off course...
