xreas with ome springs
Old 05-30-2007, 10:22 PM
aisin al's Avatar
Question xreas with ome springs
does anyone know if you can install old man emu 1.5" springs on xreas shocks? if not why?
Old 06-01-2007, 07:30 AM
Jared's Avatar
The answer is basically "no". The shocks are cross linked. So if you now change the stroke of the shock by changing the height, you will affect the opposite corner shock. For instance, if you now raise the front shock up, the rear shock will most likely become more stiff because of the fluid in the xreas system. I think the only thing you could do to add to the xreas system is spacers. In the end though, if you want to go offroad and get a lift, the only option is to rip out the xreas system and replace the shocks all around.
ZGjethro
06-07-2017 11:04 PM
A2theK
10-14-2015 07:10 AM
Cycles
09-29-2015 06:37 AM
83
09-27-2015 04:13 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: xreas with ome springs
