side view of sway-a-way lift with AAL and 1" block
There is no going down. I say up you go. Just watch the CV angles.
It looks great.
This picture brings a question to mind. I have wheeled with 2 new Tacos and really thought they would do better than they did. In the picture it shows that you have shocks outside the frame rails which makes it handle on the road much better. I wonder if this is however limiting rear articulation for off roading?
Just curious!
It looks great.
Just curious!
It looks great.
Just curious!
It looks great.
Just curious!
Looks like it is. Same thing with my 4Runner.
I had a feeling the AAL and 1" block would do that... I guess start cranking up the front, and get some diff drop spacers if you don't have any to help the CV angles. I think your best bet would be to just lose the 1" block rather than having to worry about the CV angle.
Originally Posted by Localmotion
Originally Posted by 4x4nala
My vote is remove AAL, I dislike them, and throw a little longer shackle on.
I agree. Get rid of the block.
???? AAL is add a leaf, not block.
Gotcha.....that would be the best.
But if you want to save $$, I think a 1" block is much better than AAL's. And I am sure someone is making shackles for the taco already.
didn't get new leafs because I needed to retain stock towing...
plus, AAL should make the rear a little stiffer for when I have it loaded with gear.
block was added to give it another inch ride height.
leave it as is or crank up the coil overs a little more, going down would be a waste, a diff drop and crank the coilovers seems like the best solution
How do aftermarket leaves affect towing? The leaves I had made actually allow me to tow more, well to the rating but I sag less with max tounge weight?
