MPG sensor accuracy? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 12-17-2007, 04:32 PM   #1 (permalink)
Kraeken's Avatar
Question MPG sensor accuracy?
Since I got my 07 Sport, I've been getting average mpg consistently around or above 17 mpg in city driving, and around 19-21 highway.
The other day I was on the expressway going about 55, and I had it in 4WD due to the weather and never changed it back to 2WD when I got on the highway. I looked at my computer and it was telling me my average mpg was around 23, and it even went up to 25.5! Should I trust this, or is it some type of glitch? I had just reset it after a fillup. I'm running Revo's in the stock size.
Usually when I fill up the computer says my range is in the higher mid 300's, like 365, 360, etc.
I'm realizing the math isn't working out, but when I do notice the numbers that's what they usually say.
I'm mostly wondering if it is possible to actually get that mpg in 4WD.
__________________
Ted
www.tedgormley.com
2007 Galactic Grey Sport- V6, Moonroof, XREAS, Revos, Hella 500's on a Westin Ultimate Bull Bar, Husky waterproof mats all around, Factory roof rack crossbars removed and replaced with Thule system
Kraeken is offline
Sponsored Links
To remove this ad, register today!
Old 12-17-2007, 06:59 PM   #2 (permalink)
Send a message via AIM to mheart624
no, its a glitch...your mpg is a calculation thats rarely excactly correct. would be nice though!
mheart624 is offline
Old 12-18-2007, 07:35 AM   #3 (permalink)
The fuel economy indicator is only as accurate as the odometer and whatever data the computer uses to calculate fuel usage.
If you are reading instantaneous MPG and not average MPG, you will find times when the MPG reads high during periods of reduced engine loads (downhill, tailwind, etc.). So the times you read higher MPG may not be a glitch.
I don't think there's any kind of fuel flow meter to calculate actual fuel flow or consumption. The computer would have to be able to estimate fuel consumption based on air flow, ambient temperature, coolant temperature, etc. (the same data the computer uses to control fuel mixture), and then make a MPG calculation based on how many miles are driven over a period of time.
If the fuel mixture is accurate, the fuel usage calculation should be accurate. As long as the odometer is also accurate, the MPG indicator is probably pretty close to correct.
To check it, it would be a good idea to use a GPS to check odometer accuracy. Then you would fill up, reset the MPG indicator and trip odometer, and divide how many gallons used per tank into how many miles driven per tank.
Do this for several tanks, using the GPS milage information to correct any odometer inaccuracy. Compare this to the accumulated MPG average for all of those tanks (or you can do it tank by tank).
I think you'll find that the fuel economy averaged out over a whole tank or several tanks will be fairly accurate.
__________________
'06 Tacoma TRD 4wd 4 door short bed, rear locker mod (can use in high range and 2wd now), Skyjacker 3" lift struts with new rear springs and shocks, 285/75-16 BFG All Terrains, more to come.
'08 Yamaha FJR1300 with ABS and power adjustable windshield.
'06 Yamaha Wolverine 450 sport/4wd ATV
'07 Kawasaki Brute Force 750 ATV
William is offline
Old 12-18-2007, 08:23 AM   #4 (permalink)
The computer on my 2003 V8 4Runner is usually at least 2 mpg optimistic. Use your trip odometer and divide miles driven by the number of gallons you pump in. The computer display is just not accurate.
M1911 is offline
Old 12-20-2007, 06:58 PM   #5 (permalink)
mpg
Mine is about 5 mpg optimistic, maybe it doesn't know about the supercharger
__________________
2003 4Runner V8, TRD supercharger, Borla cat-back
scharged03 is offline
Old 12-20-2007, 07:44 PM   #6 (permalink)
JGage's Avatar
Mine was about 2mpg high with the stock tires, its about 1.5 high with the one size larger Revos... IMHO, the only thing sorta right on that computer is the outside temp.
I've driven 50miles after the "range" hit zero and still had 1.2gal left in the tank.
I hope they just get rid of it on the 2009... and add the 5.7 (if Toyota is reading).
__________________
2003 Galactic Gray Limited 4WD V8 w/ X-reas.
Passenger and Driver window tint mod. <G>
Royal Purple ! Amsoil in the Diffs and TC.
"…..there’s always a way of balancing things. Someday it’ll come. Don’t hunt for it, don’t pledge revenge – revenge is for children. It’s a lot more satisfying to f#ck with their mind. Just keep your eyes open and wait for the chance. The take it for everything its worth. "
JGage is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
speedometer accuracy lee 95.5-2004 Tacomas & 96-2002 4Runners 18 06-15-2005 06:43 PM
TRD boost gauge accuracy / calibration???? yoda-g2 95.5-2004 Tacomas & 96-2002 4Runners 9 05-05-2004 08:02 PM
2000 Fuel Gauge Accuracy TSB EL010 and Me bobzemuda 95.5-2004 Tacomas & 96-2002 4Runners 11 12-22-2003 11:32 PM
Narrow band vs wide band o2 sensor accuracy Jeff B. in Michigan 95.5-2004 Tacomas & 96-2002 4Runners 6 09-01-2003 04:55 PM
22r mpg/your toyota's mpg Chanson88 95.5-2004 Tacomas & 96-2002 4Runners 0 05-26-2003 07:47 PM
2009 InternetBrands, Inc.
