| Home | Photo Gallery | Register | All Albums | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Search this Thread |
#1 (permalink) |
Lifted 4th Gen running boards or not???
I took a picture with the running boards on and one with them off. I think I like the looks of it better with out them, but was looking for other opinions.
Let me know what you think... https://home.comcast.net/~drossi4/running_boards.htm
__________________
2003 V8 4Runner SR5 ARB Onboard Air 3"RevTek lift 285/75/16 BFG AT/KO Yakima Load Warrior My 4Runner Page |
| Sponsored Links |
#2 (permalink) |
Whats up!!!
I think that in your current configuration, you should go without the runnings boards. Maybe, if you have the dough of course, get the tube bars instead. It will go good with the bar theme on your roof rack. Just my opinion, later, Joseph |
#3 (permalink) |
Off - for sure. Looks more sporty and useful.
![]() That's mine, unlifted, without boards. I think every 4th gen. that I've seen without running boards looks great ... much better than with them on. |
#4 (permalink) |
Thanks for all your opinions..The running boards will definitely be staying in the garage..
4route--I noticed in your sig. you removed the the resonator from the end of the exhaust, How does it sound now? Better?? Worse?
__________________
#5 (permalink) |
Taints2k3 -- Well ... I removed mine after I had the 14" Magnaflow on for awhile ... and when I removed the resonator, it made all the difference in the world. I was reading another thread somewhere and the guy had taken off his resonator and it didn't make any difference in sound with the stock muffler. So, I'm not sure what it would do if you have just the stock setup, but with the Magnaflow, taking the resonator off made an enormous difference and I like it so much better.
Before taking it off, there wasn't much noticeable difference between the Magnaflow sound and the stock sound .. that disappointed me because everyone said the Magnaflow would make a big difference in tone. So, I tried taking the resonator off and replacing it with a new tip which angled out, and it was 100% better. It finally let the Magnaflow sound come out, and I continue to be glad that I took that resonator off. Do you have the stock muffler ?? Here is a thread on the 4runner board that talks about the sound difference with the stock muffler: http://www.toyota-4runner.org/showth...&threadid=2525 |
#6 (permalink) |
Agree running boards should go.
I want to take mine off but wil wait till I have an alternative for stepping in(more for passengers than for me), and some side protection as well as when I finally have my lift sorted out (still getting info). Rock sliders seem to agressive for my "baby" at this point, plus it is not useful for helping people get in and out. WHere would be a good place to get tube bars and how much are they typically for 4th Gen? It would also be good to fit the light connections to the tube bars so it shows the ground and the bar itself.
__________________
___________________ *****andries***** 03 Pavement Princess 05 Mall Queen |
#7 (permalink) |
bulldog -- actually I had been meaning to ask you - how is your lift info-gathering going? I'm trying to get one too. I think I'll probably get some rock sliders sometime after my lift, as for nerf bars, let me look around on the net and if I find some, I'll PM ya.
#8 (permalink) | |
Quote:
I'm waiting for Daystar to get back to me with more info on the lift kit. It says 2.5" kit, but I'm looking for slightly less in the back as it seems the best thing to do (1.75 or 2"). They also said they will send me the installation nstructions. I currently getting/buying the required tools and waitingg to get the complete factory manual. SO it seems it will be DIY for me. I looked at the suspension quickly today and it looks like it will be very tricky to work with the XREAS tube at the bottom of the front tube, the brake line and ABS will make it tricky as well. So in the end the tools will probably cost me more than the installation, but that's part of the fun. You guys will probably het done before me, so post picks with instructions tips and tricks. If I do it before you guys I will do it then. I expect to only do it some time in April.
__________________
#9 (permalink) | |
Sponsoring Member
Quote:
![]() Did you get a tunable tip? if so, did you try moving it around for performance/tone?
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#10 (permalink) |
Gosh. I keep trying to email daystar, but it keeps getting sent back to me! I'm going to try the 2.5" kit - front and back. I doubt that I will get it done before you though -- I've been having a rough time trying to get ahold of daystar, and I don't trust myself to do the lift, so I'll have to find a place around here.
I wish you luck on your install. How did you get ahold of daystar?? Are the directions they're sending you different from the ones they have on their site?? Hmm. |
#11 (permalink) |
Mark -- I was so beat after all that. But I did post pics of the tips! And I do very much like the sound now. It isn't a tunable tip - everywhere I went acted like I was retarded when I'd ask things like that, so, I just went with a plain ole dual tip angled out. The sound is divine now though!
#12 (permalink) | |
Quote:
I have also been looking for a set of sliders that will serve both functions,help get my full size spare on the roof rack (285's are heavier than I thought!!!) and protection for the rocker panels. Seems like most of the sliders tuck under too far to be much help for standing on.. Let me know how you make out in your search. I will let you know what I find.
__________________
#13 (permalink) |
Take 'em off but be careful!!! I was cleaning out my garage the other day and noticed that the endcaps on my running boards were BROKEN!! I stored them standing up, with the rear endcap side on the ground supporting the weight of them. Well, after a few months the plastic around the bolts that held the endcap to the RB ripped mostly off. Oh well, the mounting brackets on them were so bent up from stupid off roading previous to removing them that they were worthless. Oh, the joys of owning a 260k 4runner. Kiss resale goodbye!!! Even on parts!
__________________
97 Runner SR5 4wd 300,000+ miles & Still Truckin'! |
#14 (permalink) | |
Quote:
Check you thread about lifting in Texas, I think keisur is offering to do it in Houston, might be worth the drive??
__________________
#15 (permalink) |
Not that you need another opinion but I'm in the off camp, too. I've only been around these boards a few months but even I know that sliders are in your future
it's just a matter of time and/or money.
__________________
2003 Tacoma DoubleCab |
#16 (permalink) |
it's always a matter of money! stupid money.
#17 (permalink) |
Yeah, better leave 'em off. "Well placed hazards" may wreck havoc...
__________________
4Runner Anthracite 98 LTD 3.4 AT 160K miles, 285 Revos, N91S and TRD tundra coils, Diff Drop, N86 and 891 w/ cones, 1.5" Body Lift, E-Locker w/anytime mod, 4 in. Deckplate, Amsoil air filter and fluids, Optima 34R, Yak Rack and Hull Raiser. (Wrecked 94 is still missed)-----See the pics----- |
#18 (permalink) |
mossback ... shhhhh
![]() [i hope you know i'd never actually do that] |
#19 (permalink) |
Why don't you guys try Wheelers Offroad , they have been really cool with me.
As far as the instructions go, I'm sure someone here can help you out. Hell I may even have left them in my garage. I'll check tomm or so. Doug M.
__________________
2003 Runner SE / Cruisers 1971,1980,1997(40th) & 2005 |
#20 (permalink) |
I know there are a lot of us who would be incredibly grateful to get our hands on a set of directions on how to install around the XREAS.
