Does a 2004 v8 4Runner wi 125k miles need a timing belt?
Old 10-13-2013, 05:10 PM
coopma's Avatar
I talked to someone at Toyota one time and they said it is not needed.
What else is needed at 125k miles.
Old 10-13-2013, 05:55 PM
250000_yota's Avatar
No, it most definitely does. It's due at 90k, and that happens to be an interference motor, so if it were to break, things get expensive.
Old 10-13-2013, 06:09 PM
rworegon's Avatar
Take a look here.
Old 10-13-2013, 06:18 PM
coopma's Avatar
How about the need to change trans fluid & coolant & spark plugs
I have heard the plugs are lifetime and never need to be changed.
Same with the transmission fluid and coolant.
What do you think?
Old 10-13-2013, 07:18 PM
rworegon's Avatar
I think you need to confer with the maintenance guidelines in post 3 that Toyota published for your rig.
I'm doubtful that spark plugs are a lifetime item.
It also says to replace coolant at 100K on page 32.
You are well past due on numerous maintenance items, IMO.
ErikZ1220
09-10-2015 04:53 AM
Tacoma1313
09-08-2015 01:27 PM
Tacoma1313
08-17-2015 05:44 PM
dropzone
08-11-2015 05:16 PM
MLJBikes
16
06-28-2004 06:42 PM
Quick Reply: Does a 2004 v8 4Runner wi 125k miles need a timing belt?
