Zuk mod on my 1987 4Runner using TJ springs
Old 12-30-2012, 11:02 AM
Rickstwowheels's Avatar
I found a generous local Jeep guy who let me have his old TJ springs for free. I used the rears because they are shorter to start with, and (I assumed) a softer spring rate since the front of a TJ is much heavier than the back. I did not want them overly tall or firm because I am hoping to get a soft top in the Spring and that will reduce the weight of my rear end a good bit. The two springs were roughly the same height, but I did not measure them. I started by cutting about this much off each spring to get them to fit over the top (metal) bump stop.
Then I supported the truck by the frame, removed the tires and let the suspension sag (one side at the time, if it matters). I have spring compressors ($10 pair from HF), and so it was a very simple matter of compressing them and putting them in place. I got about two inches of lift out of this mod.
Before:
After:
Old 01-03-2013, 02:48 PM
derockus's Avatar
Gotta love the no-cut ZUK mod. I used TJ front springs cut to 12". Might be a little stiff but i'd prefer it to be stiff when empty and not sagging when I'm loaded up. Nice job
Old 01-04-2013, 03:56 AM
Good point, the front springs are not progressive and I am sure they provide a greater weight capacity. I am about to lose the hard top and lighten my load so the softer progressive spring was the one for me. I cannot even tell a difference in the ride.
Old 01-04-2013, 07:31 AM
derockus's Avatar
And if you change your mind they're easy to swap out!
Old 05-31-2013, 07:16 PM
Roark's Avatar
Before:
After:
Are those 33 x 10.5 BFGs?
87turboPA
07-12-2015 07:49 AM
icentropy
07-11-2015 07:21 AM
shar
07-09-2015 12:38 PM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Zuk mod on my 1987 4Runner using TJ springs
