would u fix or let go?
Old 03-12-2012, 06:49 PM
justin_4runner's Avatar
so on friday my 91 4runner caught fire and burned the hood dist, alt, cap rotor, air box and tubes, gas return line, some wiring for injectors and air meter now my question is.... would u rebuild it or let it go and get a new one and start fresh, just a little back ground on what i have done to this rig is 5 speed swap, lsd in rear diff, motor rebuilt less than a year ago, just put new front brakes, master cylinder, rock sliders, winch and bumper, hid kit and housings,
i have an adjuster coming out tomorrow to look at it, what would u feel is a good price if im offered to buy it back?
before....
after....
Old 03-12-2012, 06:53 PM
rworegon's Avatar
You know the #1 answer, right? Time to put a 3.4 in it.
I've seen engines with more damage brought back, but I have no clue what it would cost $$ wise or time wise.
Old 03-12-2012, 06:56 PM
waskillywabbit's Avatar
3.4 swap
:wabbit2:
Old 03-12-2012, 07:04 PM
dsal_86Yota's Avatar
Originally Posted by waskillywabbit
3.4 swap
:wabbit2:
X3 Never give up on a Yota.
Old 03-12-2012, 07:11 PM
MaDkAtT44's Avatar
For sure dude,
thats not alot of damage, i've seen/caused much worse hehe, fixit
Old 03-12-2012, 07:14 PM
vasinvictor's Avatar
That aint bad. You need to go to the pick n pull.
Old 03-12-2012, 07:19 PM
93liftedyoda's Avatar
i wouldn't give up man. its worth puting back together
Old 03-12-2012, 07:24 PM
worshipmentor's Avatar
why, if youd seen what ive seen AND fixed on my 87................
DUDE>>>>>>>>>>>> break out the diphibulator and CRANK'R BACK UP!!!!!!!!!!
Old 03-12-2012, 07:38 PM
whelan709's Avatar
fix it for sure, thats nothing to re do! just a good time for some upgrades!! don't need a 3.4 swap but a cold air intake, supra maf meter, some nice wires and lines would be great! nice new distributor too!
Old 03-12-2012, 07:58 PM
i kind of want to fix but also want to just get a newer 4runner. the wife is telling me to just dump so i wanted to see what people had to say... thanks for the input. we will see what they want for buy back.
Old 03-12-2012, 08:37 PM
Black_1985_SR5's Avatar
if you dont want the truck let me know the buyback price it should be like a couple hundred bucks and ill buy it from you. 3.4 3.4 3.4!
Old 03-12-2012, 09:05 PM
MaDkAtT44's Avatar
great idea
Old 03-12-2012, 09:25 PM
wyoming9's Avatar
Red face
When a women is involved for the most part no matter what you do it will be wrong.
Not knowing your financial status can you afford to just go purchase something newer?? Do you need something to drive like right away??
Do you need a check from the insurance company to go shopping??
The bottom line is do you really want to spend the time and money to fix this one?? The mechanical and other repairs are not all that hard.
As long as I am building and repairing these trucks for fun as soon as it is because I need to it gets old real fast. Then after 30 plus years it might be understandable.
Good luck no matter how it turns out.
Old 03-12-2012, 09:34 PM
im waiting on a check to fix or replace the 4runner, what ever i get im going to stick with a yota, the wifes issue is that i drop 200-500 a month paying for items or replacing things that broke. and she just wants me to get something else.
Old 03-12-2012, 10:44 PM
Jeep Killa 99's Avatar
Wyoming
-could not have said it better
If this car means that much to you then fix it, or by a third gen
Old 03-13-2012, 04:53 AM
93toyrunner2's Avatar
I do not know what pull yards you have near you, but using the prices at the local pullapart here in Ga, I could fix that mess with under $200 max. Spend a day at your local yards gathering all the parts, hoses, air filter box, and the wiring harness from 89-92 model.
Old 03-13-2012, 09:09 AM
James Woods's Avatar
I was first offered $900 for my truck and turned it down and argued with the guy and asked to speak to his manager, 3 min later he came back on the phone and offered me $1900 and I keep the truck. Mine is a stripped down 88 22re with almost 300k on it, so you should get offered more, but I agree with everyone, buy it back and find another DD while you fix the 4runner.
Old 03-13-2012, 09:21 PM
regnar11b's Avatar
3.4 swap is the best way to go.... How did it catch fire? I know the 3vze's have tons of issues with V-Locking when your 4-wheeling but that wouldn't cause a fire.
Old 03-13-2012, 09:55 PM
from what i can tell and everybody else saying that a fuel line had a pin hole and sprayed it on a hot motor and it went up.
Old 03-13-2012, 10:14 PM
warmonger88's Avatar
definately fix it, delete the egr while you are at it too. I bet you could find at least the stock parts that burned up pretty easliy from someone on here that just doesn't want them, same with craigslist, i see the airboxes on there occasionally for a few bucks. The cold air made a huge difference on my 3.0, and even more when I removed the egr afterward.
Quick Reply: would u fix or let go?
