Wobbly CV Joint
Old 08-03-2006, 08:39 PM
creeve4's Avatar
Wobbly CV Joint
On my 94 4runner (4X4), I can move the outer CV joint (only on the drivers side) by holding on to the CV Boot. I can move the CV joint about 1/8 of an inch in any direction expect in and out. When I am driving on anything but flat, smooth pavement, I can hear the CV Joint rattle. The CV Joint boot is not damaged. Is the CV Joint bad? Could it be caused by loose or damaged bearings?
Thanks,
Christopher
Old 08-03-2006, 08:52 PM
UKMyers's Avatar
Spindle bushings are gone.. pretty common.. I just replaced mine not too long ago..had the exact same symptoms. It'll get rid of the rattle you are describing. Don't let it go forever like I did because eventually the bushing will spin on the end of your CV axle and ruin it. It will make a really loud hum for about 20 seconds and then quit if that happens.
Old 08-03-2006, 09:01 PM
ChickenLover's Avatar
Yep. I just did mine too.
Old 08-03-2006, 09:55 PM
Red3.slow's Avatar
oh damn.... Mine did that about 2000 miles ago.... Looks like I need to have those bushings replaced.
Old 08-04-2006, 05:53 AM
Flash319's Avatar
Your bushings are gone but are you sure the rattle isn't the brake pads slapping the rotor. Sometimes the springs that keep them apart stop working because they are rusted to death or have been damaged by heat.
Old 08-05-2006, 05:38 AM
creeve4's Avatar
The rattle could be caused by the brakes, which I will also check, but the Spindle bearings are definitly in need of replacement. Thank you all for your advice!
Christopher
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: Wobbly CV Joint
