wired connector next to intake (Identify)
Old 11-27-2013, 02:15 PM
stevenf's Avatar
Had some clogged injectors. Upon reassembleing I noticed this wired connector with nowhere to hook it up. Also, my temp gauge is jumping all over the place not sure if it is related.Name:  CAM00016_zps48833c26.jpg
Old 11-27-2013, 03:13 PM
SoCal4Running's Avatar
That's not a factory connector. The wire most likely is.
Started solenoid? Or does it start fine?
Old 11-27-2013, 03:39 PM
stevenf's Avatar
it starts fine, having a lack of fuel issue at the moment but that wire does have the grey coating just like the factory harness.
Old 11-27-2013, 03:44 PM
stevenf's Avatar
also have a hose fitting on top of the EGR device that goes from the intake to the block. It doesnt have a vacuum line on it. Any idea where this goes?
Old 11-27-2013, 05:01 PM
Their should be a coolant temp sensor just about where that wire is about half way back on the intake manifold between the 2nd and 3rd runners. Might go there?
Sleaker
08-26-2020 06:03 AM
steve miller
10-10-2015 01:40 AM
TDonkey
07-26-2015 10:14 AM
msane99
07-17-2015 10:13 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: wired connector next to intake (Identify)
